OMNI Plugin v3.0.2.10
    v3.0.2.10 was released to the updater today.
    Changes in this version:
    Changes to Dim/On/Off code to support individual unit types
    Always make a backup of your system before loading a new version.
    Post any issues you have with this version in this thread.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
    The plugin is now available in the updater.
    Sorry for the delay...
      Reserved 2
        Originally posted by rmasonjr View Post
        Sorry guys - it's still not showing in the updater after using the new portal.
        I opened a support ticket with HST to get a status.
        Will report back here when it's available in the updater...
          It's in the updater now.
            Thank you Rob! Updated.
            May-16 9:28:16 AM Updater Extracting files from zip file: /HomeSeer/Updates3/OMNI3.0.2.10/OMNI_Config.zip Destination: /HomeSeer/Config/
            May-16 9:28:16 AM Updater Extraction Complete.
            May-16 9:28:16 AM Updater Extracting files from zip file: OMNI_Images.zip
            May-16 9:28:16 AM Updater Install/Update of package OMNI was successful.
              .10 installed. No joy on the dimming function.
              Rob, I sent logs to you twice. The second email contains logs that show what happened when I manipulated unit 47 via Haiku and unit 39 via the plugin.
              Good luck.
                Good luck.
                Thanks Tom. I am almost out of ideas. I need to open a ticket with Leviton and reference the omnilink protocol. Your logs show your ALC device types, and it looks like I'm sending the right command, but obviously, something else is going on.
                  New version posted for dimming:
                  https://forums.homeseer.com/showthread.php?t=195815
