What to buy rfxtrx433, rfxlan, rfxtrx315
    I just don't know why and how to chose one over the other.
    Any input is appreciated.
    I want t o replace my w800 which has a shorter than desired range.
    Transitioning to HS3Pro .298 - WinXPEmbedded
    RFXtrx315
    - receives US X10 (310MHz) sensors
    - or US Visonic PowerCode (315MHz) sensors
    RFXLAN
    - receives many 433.92MHz sensors (mainly European)
    - transmits 433.92MHz signals to control European devices.
    See also the Will Support list on the RFXCOM web site
    RFXrec433
    - receives a lot more 433.92MHz sensors
    RFXtrx433
    - transmits 433.92MHz signals to control many many European devices.
    Older RFXCOM USB versions:
    USB 310MHz receiver for US X10 only
    USB 433.92MHz receiver for:
    - European X10
    - Oregon Scientific
    - OWL CM113,CM119
    - Electrisave
    - cent-a-meter
    - HomeEasy
    - Chacon
    - NEXA
    - KlikAanKlikUit
    - ELRO
    - RFXSensor
    - RFXMeter
    - KD101 smoke detector
    - ATI Remotes
    Last edited by b_weijenberg; October 12, 2013, 02:24 PM. Reason: old USB version added
      Re: What to buy rfxtrx433, rfxlan, rfxtrx315
      Oh wow, i guess the euro market version does a lot more!
      Too bad they dont make one that does both freqs. I wanted something that would do us x10 and oregon sci stuff. Doesnt look like they make such a monster yet.
      Thanks for the input.
      Sent from my GT-P1000 using Tapatalk 2
        I currently have an RFXLAN with LAN i/face and HS2.
        When I upgrade to HS3 I would like to control my Somfy RTS blinds - is there an upgrade to the RFXLAN available?
        If not, can I run an RFXLAN & an RFXtrx433E at the same time? The range is going to be an issue if I can only use the USB device.
        Regards
        Scott
          The RFXLAN cannot be updated but can be used together with the RFXtrx433E.
          If the Homeseer system is not on the right place for RF you can connect the RFXtrx to a RaspberryPI and install socat or ser2com. With this you can connect the RFXtrx over LAN.
            Cheers Bert,
            Is there going to be an upgrade to RFXLAN or is it obsolete for new features already?
              RFXLAN has never had updates for the receiver/transmitter firmware because it does not have flash memory that could be updated by the user.
              The RFXLAN Ethernet controller has user up-gradable firmware to flash TCP/IP or xPL firmware.
