Thanks for creating this plugin! I've just upgraded to HS3 and installed the plugin to see how it works. It has been working fine, but I was getting error messages in the HS3 console:
11/30/2014 3:12:36 PM ~!~CONCORD~!~WriteLog() - Error Could not find a part of the path 'C:\Program Files (x86)\HomeSeer HS3\Logs\CONCORD\CONCORD_2014-11-30.log'.
Apparently, the "Concord" directory wasn't created under HomeSeer HS3\Logs during install. Not sure what happened.
Once I manually created the directory, the log files were created and the errors dissappeared.
Hope this helps!
Hope this helps!
