Simply Automated UPB UCQF-W 3-Speed Fan Controller
    Spud- I see the problem now.
    The links can and do activate the fan switch properly, just as if you pressed the switch on the fan controller itself. The problem comes in when you want HS to know the current state of the fan controller.
    As it operates now, there is no way to know if the button is pressed manually.
    So if you want an event set the fan speed to medium when its hot, but someone had already manually set it to high, you don't want to lower the speed. Just an example why HS needs to properly track the fan controller state.
    I don't know if its possible because of the nature of the fan controller to do this with a plugin or not.
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
      I don't have one of these yet, but perhaps you can configure the switch to receive some links. The received links would be separate from the button activations. Seems like this would be easy to setup as long as you can configure a received link to activate a specific speed. Then you would create one UPB link for each speed you want to be able to activate with homeseer.
        Hi Spud,
        I am beginning to mess with these fan controllers again and was wondering if this is normal for every plugin restart for every fan controller I have (I have 4 of these now):
        May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: device 134 is not a keypad, ignoring button record
        May-05 8:41:12 AM UPBSpud DEBUG DEVICE[134]:: Marked device Ceiling Fan (134) as NON-DIMMING
        May-05 8:41:12 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Aubrie's Bedroom] -- 3 rooms now known
        May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Receive Component Count mismatch on deviceID 134 between import file (8) and device (16)
        May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 134 between import file (0) and device (1)
        May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 134 between import file (4) and device (1) -- updating device
        May-05 8:41:12 AM UPBSpud DEBUG Product Code/ID: 52
        May-05 8:41:12 AM UPBSpud DEBUG Manufacturer Code/ID: 4
        May-05 8:41:12 AM UPBSpud DEBUG A new generic UPB Device found!!
        I am just trying to make sure that all of the imports for these devices are as expected before I try to integrate them again.
        Specifically these three lines.....are they an issue and why would they be a mismatch with every plugin restart?
        -Travis
          Hi Spud,
          Resuming our issue from the past with this device, here's a simple issue that we can test with fixes since I have a test switch now setup.
          Switch Physical Status - Off Indicator Lit, Homeseer Off Indicator Lit (On)
          Then Press Off on the Physical Switch:
          Here's the Log:
          May-06 6:41:08 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
          May-06 6:41:08 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878608DC]
          May-06 6:41:07 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 8
          May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878608DD]
          May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
          May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502048720FFFFC7]
          May-06 6:41:07 AM UPBSpud DEBUG Device 135 transmitted link 4 with action Activate => Firing event 9686
          May-06 6:41:06 AM UPBSpud DEBUG LINK[4]:: Got Link ACTIVATE
          May-06 6:41:06 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402048720FFFFC8]
          Here's what happens:
          The Indicator Device for the High in HomeSeer changes to On. The original Indicator Device for Off Remains Lit. The physical device is as expected (Only Off LED lit).
          Using Upstart only to control links and the physical switch never seems to have an issue. I attached the UpStart configuration screenshots this time.
          Any ideas for the incorrect tracking of the HS LED Indicator status?
          -Travis
            I'm confused by your test , do you try to change from High to Off, or from Off to High? because you said Off indicator lit, and then you say you press the Off button on the physical switch.
            the following message is definitely weird:
            It is as if the level on channel 0 was binary coded to represent the state of all indicators or something like that.
            When this happens can you try to select the channel device on the management page, and click the poll button to see what state report message is sent in this case.
              #21
              Sorry for the confusion. I am trying to come up with a test that is simple and doesn't have us moving between speeds etc on the fan which can confuse things. The messages generated in the log are when physically pressing the Off Button while the unit is already off (Off Indicator Lit in HS and on the Controller itself). The physical device status didn't change, the Off indicator stays on but in HS, suddenly the "High" LED and the "Off" LED were both lit. There is no reason for the High LED to be lit and it isn't in sync with the physical device when it shows it in HS that way. Polling doesn't fix it either. Whenever I poll the device, the response is always the say, regardless of the indicators:
              Polling...
              3 @ Polling: Downstairs Kitchen Ceiling Fan Speed - Off LED (Status is: 0)
              2 @ Polling: Downstairs Kitchen Ceiling Fan Speed - High LED (Status is: 0)
              1 @ Polling: Downstairs Kitchen Ceiling Fan Speed - Medium LED (Status is: 0)
              0 @ Polling: Downstairs Kitchen Ceiling Fan Speed - Low LED (Status is: 0)
              Done
              -Travis
                #22
                Polling...
                Done
                -Travis
                ok it's clear now, and I think I understand where the problem is. Could you do the following tests and post the logs for each:
                (1) Starting with the controller being on High speed, press the off button on the physical switch
                (2) Starting with the controller being off, press the High button on the physical switch
                (3) Starting with the controller being on High speed, press the Low button on the physical switch
                thanks
                  #23
                  Hey Spud,
                  Here's a little more information I was able to gather today. I contacted Simply Automated and spoke to Millard. He ran through the setup with a test unit over there and he recreated the same issue. He doesn't know why the controller is sending out the value of 4 and 8 etc either. He suspects it is a firmware thing or the UpStart is not programming the controller correctly. Either way, he is going to figure out what the issue is and if it's intentional, then what the values mean for the interpretation by the Plug-In. That said, if you are on a road to figuring it out, let's keep going that way since you might be able to fix by ignoring a command or by interpreting what the values actually mean before they could fix the issue or identify it. Since UPB hardware isn't firmware End-User firmware upgradeable, if that's the issue, I would have to send them back in once they have a fix.
                  It appears that Channel 0 can have values of 0,1,2,4,8 or 100 as far as I can tell. He was expecting it to be 0 and 100 only.
                  Here's the info you asked for:
                  May-06 5:12:20 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                  May-06 5:12:20 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878608DC]
                  May-06 5:12:19 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 8
                  May-06 5:12:19 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878608DD]
                  May-06 5:12:19 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                  May-06 5:12:19 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502048720FFFFC7]
                  May-06 5:12:19 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 3 from 0 to 100
                  May-06 5:12:18 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 100 to 0
                  May-06 5:12:18 PM UPBSpud DEBUG Device 135 transmitted link 4 with action Activate => Firing event 9686
                  May-06 5:12:17 PM UPBSpud DEBUG LINK[4]:: Got Link ACTIVATE
                  May-06 5:12:17 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402048720FFFFC8]
                  May-06 5:13:19 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                  May-06 5:13:19 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878601E3]
                  May-06 5:13:19 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 100 to 1
                  May-06 5:13:19 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878601E4]
                  May-06 5:13:19 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502018720FFFFCA]
                  May-06 5:13:18 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 3 from 100 to 0
                  May-06 5:13:17 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 100
                  May-06 5:13:17 PM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 9335
                  May-06 5:13:17 PM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 8232
                  May-06 5:13:16 PM UPBSpud DEBUG LINK[1]:: Got Link ACTIVATE
                  May-06 5:13:16 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402018720FFFFCB]
                  May-06 5:14:40 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                  May-06 5:14:40 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878604E0]
                  May-06 5:14:39 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 4
                  May-06 5:14:39 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878604E1]
                  May-06 5:14:39 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                  May-06 5:14:39 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502038720FFFFC8]
                  May-06 5:14:38 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 2 from 0 to 100
                  May-06 5:14:38 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 100 to 0
                  May-06 5:14:38 PM UPBSpud DEBUG Device 135 transmitted link 3 with action Activate => Firing event 2737
                  May-06 5:14:37 PM UPBSpud DEBUG LINK[3]:: Got Link ACTIVATE
                  May-06 5:14:37 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402038720FFFFC9]
                  Thanks again for your help with this,
                  -Travis
                    #24
                    Can you test version 3.0.0.32 attached. In this version I have handled this device in a specific class that ignores the state reports, that should fix the issue.
                      #25
                      Hi Spud,
                      I updated to the .32 build and tested as requested. The LED Devices were no longer tracking so I deleted them and reimported the UpStart Export. They were recreated but remained the same. There is no updating of the LED status in HS in any of the 4 button modes. I redid the tests you asked before...results here:
                      May-08 9:01:43 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                      May-08 9:01:43 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878608DC]
                      May-08 9:01:42 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 8
                      May-08 9:01:42 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878608DD]
                      May-08 9:01:42 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                      May-08 9:01:42 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502048720FFFFC7]
                      May-08 9:01:41 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 1 to 0
                      May-08 9:01:41 AM UPBSpud DEBUG Device 135 transmitted link 4 with action Activate => Firing event 9686
                      May-08 9:01:40 AM UPBSpud DEBUG LINK[4]:: Got Link ACTIVATE
                      May-08 9:01:40 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402048720FFFFC8]
                      May-08 9:02:46 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                      May-08 9:02:46 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878601E3]
                      May-08 9:02:46 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 100 to 1
                      May-08 9:02:46 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878601E4]
                      May-08 9:02:46 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502018720FFFFCA]
                      May-08 9:02:45 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 8 to 100
                      May-08 9:02:45 AM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 9335
                      May-08 9:02:45 AM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 8232
                      May-08 9:02:44 AM UPBSpud DEBUG LINK[1]:: Got Link ACTIVATE
                      May-08 9:02:44 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402018720FFFFCB]
                      May-08 9:03:16 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                      May-08 9:03:16 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878604E0]
                      May-08 9:03:15 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 4
                      May-08 9:03:15 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878604E1]
                      May-08 9:03:15 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                      May-08 9:03:15 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502038720FFFFC8]
                      May-08 9:03:14 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 1 to 0
                      May-08 9:03:14 AM UPBSpud DEBUG Device 135 transmitted link 3 with action Activate => Firing event 2737
                      May-08 9:03:13 AM UPBSpud DEBUG LINK[3]:: Got Link ACTIVATE
                      May-08 9:03:13 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402038720FFFFC9]
                      Thanks again for your help with this...
                      -Travis
                        #26
                        ooops, sorry, bad copy/paste in the code I changed, could you try again with .33 attached. Please post the logs you get for the fan controller when you import.
                          #27
                          Hi Spud,
                          Here's the entire log from the update to .33. Note that my Test Fan Device is the one that is UID 135. The LED Device Status is still not updating in this version, not sure if it was supposed to at this point though.....
                          May-08 10:23:28 AM UPBSpud INFO Checking HS Devices Completed
                          May-08 10:23:23 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:23:23 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880F01CCFF260077]
                          May-08 10:23:22 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:23:22 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880E01CCFF260078]
                          May-08 10:23:21 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880D01CCFF260079]
                          May-08 10:23:21 AM UPBSpud DEBUG UPB_RCVR:: Recieved message from/for network #1 which is not a known network -- message ignored
                          May-08 10:23:20 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880C01CCFF26007A]
                          May-08 10:23:20 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:23:20 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880F0144FF26649B]
                          May-08 10:23:19 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:23:19 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880E0144FF26649C]
                          May-08 10:23:19 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880D0144FF26649D]
                          May-08 10:23:18 AM UPBSpud DEBUG UPB_RCVR:: Recieved message from/for network #1 which is not a known network -- message ignored
                          May-08 10:23:18 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU880C0144FF26649E]
                          May-08 10:23:17 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:23:17 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU0915015AFF22000066]
                          May-08 10:23:17 AM UPBSpud DEBUG UPB_RCVR:: Recieved message from/for network #1 which is not a known network -- message ignored
                          May-08 10:23:16 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU0914015AFF22000067]
                          May-08 10:23:16 AM Event Event Trigger "Lights - Automatic Dimming (Automation) Aubries Bedroom - Lighting - Automatic Dimming - Not Occupied"
                          May-08 10:23:07 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:23:06 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:23:06 AM UPBSpud DEBUG PIM_SEND:: Message ID 6 confirmed sent successfully
                          May-08 10:23:05 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=6)
                          May-08 10:23:05 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=6)
                          May-08 10:23:04 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140287FF302D ]
                          May-08 10:23:04 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 6 to PIM, retry count=0
                          May-08 10:23:03 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 6)
                          May-08 10:23:03 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:23:03 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:23:03 AM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                          May-08 10:23:02 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (135)
                          May-08 10:23:02 AM UPBSpud DEBUG PIM_SEND:: Message ID 5 confirmed sent successfully
                          May-08 10:23:01 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=5)
                          May-08 10:23:00 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=5)
                          May-08 10:22:59 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140286FF302E ]
                          May-08 10:22:59 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 5 to PIM, retry count=0
                          May-08 10:22:59 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 5)
                          May-08 10:22:59 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:22:58 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:22:57 AM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                          May-08 10:22:57 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (134)
                          May-08 10:22:56 AM UPBSpud DEBUG PIM_SEND:: Message ID 4 confirmed sent successfully
                          May-08 10:22:56 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=4)
                          May-08 10:22:56 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=4)
                          May-08 10:22:55 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140285FF302F ]
                          May-08 10:22:55 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 4 to PIM, retry count=0
                          May-08 10:22:55 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 4)
                          May-08 10:22:54 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:22:53 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:22:53 AM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                          May-08 10:22:53 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (133)
                          May-08 10:22:52 AM UPBSpud DEBUG PIM_SEND:: Message ID 3 confirmed sent successfully
                          May-08 10:22:52 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=3)
                          May-08 10:22:51 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=3)
                          May-08 10:22:51 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140284FF3030 ]
                          May-08 10:22:50 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 3 to PIM, retry count=0
                          May-08 10:22:50 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 3)
                          May-08 10:22:50 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:22:49 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:22:49 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:22:49 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502008386000067]
                          May-08 10:22:49 AM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                          May-08 10:22:48 AM UPBSpud DEBUG UPB_RCVR:: Unable to find LINK with ID 0
                          May-08 10:22:48 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (132)
                          May-08 10:22:48 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402008386000068]
                          May-08 10:22:48 AM UPBSpud DEBUG PIM_SEND:: Message ID 2 confirmed sent successfully
                          May-08 10:22:48 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=2)
                          May-08 10:22:48 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=2)
                          May-08 10:22:47 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                          May-08 10:22:47 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080502FF828600EA]
                          May-08 10:22:45 AM UPBSpud DEBUG DEVICE[130]:: Level changing on channel 0 from -1 to 0
                          May-08 10:22:44 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140283FF3031 ]
                          May-08 10:22:44 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 2 to PIM, retry count=0
                          May-08 10:22:43 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 2)
                          May-08 10:22:43 AM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                          May-08 10:22:43 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080402FF828600EB]
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                          May-08 10:22:42 AM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                          May-08 10:22:42 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Remote-IO (131)
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: Message ID 1 confirmed sent successfully
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=1)
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=1)
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140282FF3032 ]
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: Sending Message ID 1 to PIM, retry count=0
                          May-08 10:22:42 AM UPBSpud INFO Checking HS Devices Started
                          May-08 10:22:42 AM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 1)
                          May-08 10:22:42 AM UPBSpud INFO Import of UPStart file completed
                          May-08 10:22:42 AM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Pool - Speed (130)
                          May-08 10:22:42 AM UPBSpud DEBUG UPStart_IMPORT:: device 135 is not a keypad, ignoring button record
                          May-08 10:22:41 AM UPBSpud DEBUG UPStart_IMPORT:: device 135 is not a keypad, ignoring button record
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Kitchen] -- 6 rooms now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Pool] -- 5 rooms now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Pool Control] -- 4 rooms now known
                          May-08 10:22:41 AM UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 131 between import file (2) and device (5) -- updating device
                          May-08 10:22:41 AM UPBSpud DEBUG UPStart_IMPORT:: device 134 is not a keypad, ignoring button record
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Aubrie's Bedroom] -- 3 rooms now known
                          May-08 10:22:41 AM UPBSpud DEBUG UPStart_IMPORT:: device 133 is not a keypad, ignoring button record
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Annie's Bedroom] -- 2 rooms now known
                          May-08 10:22:41 AM Plug-In Finished initializing plug-in UPBSpud
                          May-08 10:22:41 AM UPBSpud DEBUG UPStart_IMPORT:: device 132 is not a keypad, ignoring button record
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Master Bedroom] -- 1 rooms now known
                          May-08 10:22:41 AM UPBSpud DEBUG PIM_SEND:: Got ACK from PIM, but no current command to apply it toward
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Channel 2 Open (232)] -- 30 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Channel 2 Closed (231)] -- 29 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Compressor Relay - Off (230)] -- 28 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Compressor Relay - On (229)] -- 27 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Input 3 Open (228)] -- 26 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Input 3 Closed (227)] -- 25 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote IO Control - Speed Down (226)] -- 24 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote IO Control - Speed Up (225)] -- 23 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Off (116)] -- 22 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Low (115)] -- 21 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Medium (114)] -- 20 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - High (113)] -- 19 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Off (112)] -- 18 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Low (111)] -- 17 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Medium (110)] -- 16 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - High (109)] -- 15 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Off (108)] -- 14 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Low (107)] -- 13 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Medium (106)] -- 12 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - High (105)] -- 11 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 20% (102)] -- 10 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 40% (101)] -- 9 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 60% (100)] -- 8 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 80% (99)] -- 7 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 0% (98)] -- 6 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 100% (97)] -- 5 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Off (4)] -- 4 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Low (3)] -- 3 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Medium (2)] -- 2 links now known
                          May-08 10:22:41 AM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - High (1)] -- 1 links now known
                          May-08 10:22:41 AM UPBSpud INFO Import of UPStart file started
                          May-08 10:22:41 AM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[70028E ]
                          May-08 10:22:41 AM UPBSpud DEBUG UPB_RCVR:: PIM Port opened and installed
                          May-08 10:22:41 AM UPBSpud DEBUG PIM_SEND:: PIM Adapter starting sender thread
                          May-08 10:22:41 AM UPBSpud DEBUG UPB_MGR:: Activating media adapter
                          May-08 10:22:41 AM UPBSpud DEBUG UPB_MGR:: Initializing media adapter
                          May-08 10:22:41 AM UPBSpud INFO UPBSpud version 3.0.0.33
                          May-08 10:22:41 AM Info Plugin UPBSpud has connected. IP:127.0.0.1:55325
                          May-08 10:22:28 AM Updater Install/Update of package UPBSpud was successful.
                          May-08 10:22:28 AM Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\UPBSpud.ini
                          May-08 10:22:28 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\UPBSpud\UPB4CSharp.dll
                          May-08 10:22:28 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_UPBSpud.exe.config
                          May-08 10:22:28 AM Updater Extraction Complete.
                          May-08 10:22:28 AM Updater Extracting files from zip file: images.zip
                          May-08 10:22:28 AM Updater Installing package UPBSpud
                          May-08 10:22:28 AM Updater Using local file: UPBSpud_3-0-0-33.zip
                          May-08 10:22:28 AM Updater Downloading update: UPBSpud
                          May-08 10:22:28 AM Updater Starting download of updates
                          -Travis
                            #28
                            Yes this version is supposed to fix the issue were the High channel device was updated incorrectly when you press physically the switch:
                            You should see some debug log messages like this one:
                            "Ignoring device state report for fan controller"
                            Could you try to delete your channel devices and then reimport or restart the plug-in. Thanks.
                              #29
                              Hi Spud,
                              That previous report was based off doing exactly what you asked. This time I deleted all 8 Devices for Unit 135 (Scene/Links and Channels) and restarted the Plug-In. Also I tested them as we had done before. I don't see that message anywhere when testing.
                              Here are the test results:
                              May-08 3:52:15 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:52:15 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878608DC]
                              May-08 3:52:14 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 8
                              May-08 3:52:14 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878608DD]
                              May-08 3:52:14 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:52:14 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502048720FFFFC7]
                              May-08 3:52:13 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 1 to 0
                              May-08 3:52:13 PM UPBSpud DEBUG Device 135 transmitted link 4 with action Activate => Firing event 9686
                              May-08 3:52:12 PM UPBSpud DEBUG LINK[4]:: Got Link ACTIVATE
                              May-08 3:52:12 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402048720FFFFC8]
                              May-08 3:52:45 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:52:45 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878601E3]
                              May-08 3:52:44 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 100 to 1
                              May-08 3:52:44 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878601E4]
                              May-08 3:52:44 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:52:44 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502018720FFFFCA]
                              May-08 3:52:43 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 8 to 100
                              May-08 3:52:43 PM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 9335
                              May-08 3:52:43 PM UPBSpud DEBUG Device 135 transmitted link 1 with action Activate => Firing event 8232
                              May-08 3:52:42 PM UPBSpud DEBUG LINK[1]:: Got Link ACTIVATE
                              May-08 3:52:42 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402018720FFFFCB]
                              May-08 3:53:11 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:53:11 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878604E0]
                              May-08 3:53:10 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 4
                              May-08 3:53:10 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878604E1]
                              May-08 3:53:10 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:53:10 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502038720FFFFC8]
                              May-08 3:53:09 PM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 1 to 0
                              May-08 3:53:09 PM UPBSpud DEBUG Device 135 transmitted link 3 with action Activate => Firing event 2737
                              May-08 3:53:09 PM UPBSpud DEBUG LINK[3]:: Got Link ACTIVATE
                              May-08 3:53:09 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402038720FFFFC9]
                              Here are the log results from the initial restart of the Plug-In up until I began testing:
                              May-08 3:49:50 PM Z-Wave HomeSeer SmartStick+: Z-Wave Wake-Up 'No More Info' Notification sent to Node 11(Upstairs Office Loft Smoke Alarm - Root).
                              May-08 3:49:50 PM Event Event Trigger "Smoke & CO Alarms (Timers) Office Loft - Smoke - Heartbeat - Timer Reset"
                              May-08 3:49:50 PM Z-Wave HomeSeer SmartStick+: Device (Node 11) woke up and Poll Device for Upstairs Office Loft Smoke Alarm - Status was successfully sent.
                              May-08 3:49:50 PM Z-Wave HomeSeer SmartStick+: Wake-Up Notification Processing for Node 11 (Upstairs Office Loft Smoke Alarm - Root)
                              May-08 3:49:50 PM Z-Wave HomeSeer SmartStick+: Z-Wave Wake-Up Notification Received for Node 11
                              May-08 3:49:42 PM UPBSpud INFO Checking HS Devices Completed
                              May-08 3:49:19 PM UPBSpud INFO UPB Link Kitchen - Ceiling Fan - Off created
                              May-08 3:49:18 PM UPBSpud INFO UPB Link Kitchen - Ceiling Fan - Low created
                              May-08 3:49:17 PM UPBSpud INFO UPB Link Kitchen - Ceiling Fan - Medium created
                              May-08 3:49:16 PM UPBSpud INFO UPB Link Kitchen - Ceiling Fan - High created
                              May-08 3:49:15 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:49:15 PM UPBSpud INFO UPB Device Ceiling Fan - Ch 4 created
                              May-08 3:49:14 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:49:14 PM UPBSpud DEBUG PIM_SEND:: Message ID 6 confirmed sent successfully
                              May-08 3:49:14 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=6)
                              May-08 3:49:13 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=6)
                              May-08 3:49:13 PM UPBSpud INFO UPB Device Ceiling Fan - Ch 3 created
                              May-08 3:49:13 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140287FF302D ]
                              May-08 3:49:13 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 6 to PIM, retry count=0
                              May-08 3:49:13 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 6)
                              May-08 3:49:13 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:49:12 PM UPBSpud INFO UPB Device Ceiling Fan - Ch 2 created
                              May-08 3:49:12 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:49:12 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:49:12 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (135)
                              May-08 3:49:12 PM UPBSpud DEBUG PIM_SEND:: Message ID 5 confirmed sent successfully
                              May-08 3:49:12 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=5)
                              May-08 3:49:11 PM UPBSpud INFO UPB Device Ceiling Fan - Ch 1 created
                              May-08 3:49:11 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=5)
                              May-08 3:49:11 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140286FF302E ]
                              May-08 3:49:11 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 5 to PIM, retry count=0
                              May-08 3:49:11 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 5)
                              May-08 3:49:11 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:49:10 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:49:09 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:49:09 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (134)
                              May-08 3:49:09 PM UPBSpud DEBUG PIM_SEND:: Message ID 4 confirmed sent successfully
                              May-08 3:49:09 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=4)
                              May-08 3:49:08 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=4)
                              May-08 3:49:07 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140285FF302F ]
                              May-08 3:49:07 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 4 to PIM, retry count=0
                              May-08 3:49:07 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 4)
                              May-08 3:49:07 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:49:06 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:49:06 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:49:05 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (133)
                              May-08 3:49:05 PM UPBSpud DEBUG PIM_SEND:: Message ID 3 confirmed sent successfully
                              May-08 3:49:04 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=3)
                              May-08 3:49:04 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=3)
                              May-08 3:49:04 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140284FF3030 ]
                              May-08 3:49:03 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 3 to PIM, retry count=0
                              May-08 3:49:03 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 3)
                              May-08 3:49:02 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:49:01 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:49:01 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:49:01 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:49:01 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502008386000067]
                              May-08 3:49:00 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Ceiling Fan (132)
                              May-08 3:49:00 PM UPBSpud DEBUG UPB_RCVR:: Unable to find LINK with ID 0
                              May-08 3:49:00 PM UPBSpud DEBUG PIM_SEND:: Message ID 2 confirmed sent successfully
                              May-08 3:49:00 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402008386000068]
                              May-08 3:49:00 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=2)
                              May-08 3:49:00 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=2)
                              May-08 3:48:59 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
                              May-08 3:48:59 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080502FF828600EA]
                              May-08 3:48:57 PM UPBSpud DEBUG DEVICE[130]:: Level changing on channel 0 from -1 to 0
                              May-08 3:48:56 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140283FF3031 ]
                              May-08 3:48:56 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 2 to PIM, retry count=0
                              May-08 3:48:56 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 2)
                              May-08 3:48:56 PM UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms
                              May-08 3:48:55 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080402FF828600EB]
                              May-08 3:48:55 PM UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply
                              May-08 3:48:55 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:48:55 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Remote-IO (131)
                              May-08 3:48:55 PM UPBSpud DEBUG PIM_SEND:: Message ID 1 confirmed sent successfully
                              May-08 3:48:55 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=1)
                              May-08 3:48:55 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=1)
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140282FF3032 ]
                              May-08 3:48:54 PM UPBSpud INFO Checking HS Devices Started
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 1 to PIM, retry count=0
                              May-08 3:48:54 PM UPBSpud INFO Import of UPStart file completed
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 1)
                              May-08 3:48:54 PM UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
                              May-08 3:48:54 PM UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Pool - Speed (130)
                              May-08 3:48:54 PM UPBSpud DEBUG UPStart_IMPORT:: device 135 is not a keypad, ignoring button record
                              May-08 3:48:54 PM Plug-In Finished initializing plug-in UPBSpud
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Kitchen] -- 6 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Pool] -- 5 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Pool Control] -- 4 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 131 between import file (2) and device (5) -- updating device
                              May-08 3:48:54 PM UPBSpud DEBUG UPStart_IMPORT:: device 134 is not a keypad, ignoring button record
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Aubrie's Bedroom] -- 3 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG UPStart_IMPORT:: device 133 is not a keypad, ignoring button record
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Annie's Bedroom] -- 2 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG UPStart_IMPORT:: device 132 is not a keypad, ignoring button record
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Room [Master Bedroom] -- 1 rooms now known
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: Got ACK from PIM, but no current command to apply it toward
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Channel 2 Open (232)] -- 30 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Channel 2 Closed (231)] -- 29 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Compressor Relay - Off (230)] -- 28 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Compressor Relay - On (229)] -- 27 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Input 3 Open (228)] -- 26 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote-IO - Input 3 Closed (227)] -- 25 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote IO Control - Speed Down (226)] -- 24 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Remote IO Control - Speed Up (225)] -- 23 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Off (116)] -- 22 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Low (115)] -- 21 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - Medium (114)] -- 20 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Master Bedroom - Ceiling Fan - High (113)] -- 19 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Off (112)] -- 18 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Low (111)] -- 17 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - Medium (110)] -- 16 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Annie's Bedroom - Ceiling Fan - High (109)] -- 15 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Off (108)] -- 14 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Low (107)] -- 13 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - Medium (106)] -- 12 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Aubrie's Bedroom - Ceiling Fan - High (105)] -- 11 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 20% (102)] -- 10 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 40% (101)] -- 9 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 60% (100)] -- 8 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 80% (99)] -- 7 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 0% (98)] -- 6 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Pool - Speed 100% (97)] -- 5 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Off (4)] -- 4 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Low (3)] -- 3 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - Medium (2)] -- 2 links now known
                              May-08 3:48:54 PM UPBSpud DEBUG NETWORK[2]:: Added Link [Kitchen - Ceiling Fan - High (1)] -- 1 links now known
                              May-08 3:48:54 PM UPBSpud INFO Import of UPStart file started
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[70028E ]
                              May-08 3:48:54 PM UPBSpud DEBUG UPB_RCVR:: PIM Port opened and installed
                              May-08 3:48:54 PM UPBSpud DEBUG PIM_SEND:: PIM Adapter starting sender thread
                              May-08 3:48:54 PM UPBSpud DEBUG UPB_MGR:: Activating media adapter
                              May-08 3:48:54 PM UPBSpud DEBUG UPB_MGR:: Initializing media adapter
                              May-08 3:48:54 PM UPBSpud INFO UPBSpud version 3.0.0.33
                              May-08 3:48:54 PM Info Plugin UPBSpud has connected. IP:127.0.0.1:60716
                              Thanks again for all of your help with the troubleshooting of this issue!!
                              -Travis
                                #30
                                Hey Spud,
                                Anything else you needed me to do? I will be able to test again later this evening.
                                -Travis
