Aeotec Siren doesn't add properly to network
    I just received a brand new Aeotec Siren (z-wave plus, gen 5). I have a z-stick. I added the device to the z-stick and then imported. A device was created but it has no controls. Got the following messages in the log. Tried twice with same results. Anyone else been able to successfully add this device? Note, I changed the text to red to highlight the issue.
    Jan-02 12:42:34 PM 	  	Z-Wave 	Finished with Z-Wave device synchronization.
    Jan-02 12:42:34 PM 	  	Z-Wave 	Setting a polling interval of 21 Minutes, 10 Seconds on device Node 20 Z-Wave Aeon Labs Switch Binary
    Jan-02 12:42:26 PM 	  	Z-Wave 	Getting SECURITY class information for node 20
    [COLOR="Red"]Jan-02 12:42:26 PM 	  	Z-Wave Warning 	If this is an import, you may need to remove and add the device as some devices cannot be added with an import.
    Jan-02 12:42:26 PM 	  	Z-Wave Warning 	Failed to get a SECURITY SCHEME or verify the key from node 20. Device may not be added properly to HomeSeer.
    Jan-02 12:42:26 PM 	  	Z-Wave Error 	Z-Wave was unable to negotiate a compatible security scheme with node 20
    Jan-02 12:42:17 PM 	  	Z-Wave 	Starting Z-Wave Polling for Network E594823C...
    Jan-02 12:42:09 PM 	  	Z-Wave 	Negotiating or Verifying SECURITY SCHEME for node 20[/COLOR]
    Jan-02 12:42:09 PM 	  	Z-Wave 	Z-Wave manufacturer information for node 20, ID: 134=86H (Aeon Labs), Type: 260=104H, ID: 80=50H
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Contacting node 20 to get supported features
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 CONTROLS class: COMMAND_CLASS_HAIL
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 CONTROLS class: COMMAND_CLASS_DEVICE_RESET_LOCALLY
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_MARK
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_SECURITY
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_POWERLEVEL
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_FIRMWARE_UPDATE_MD_V2
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_VERSION_V2
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_SCENE_ACTUATOR_CONF
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_SCENE_ACTIVATION
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_MANUFACTURER_SPECIFIC_V2
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_ASSOCIATION_GRP_INFO_V2
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_ASSOCIATION_V2
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_CONFIGURATION_V4
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_SWITCH_BINARY
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 supports class: COMMAND_CLASS_ZWAVEPLUS_INFO
    Jan-02 12:42:09 PM 	  	Z-Wave 	Barb Z-Wave controller: Node 20 is reporting 14 command classes in the node information.
    Jan-02 12:42:09 PM 	  	Z-Wave 	Checking if we can reach node 20
    Jan-02 12:42:09 PM 	  	Z-Wave 	Getting class information for node 20...
    After repeated tries, no luck. Decided to order another brand siren and return this one. The replacement is working fine.
