We had a server crash as it was too cold in my shed and everything turned off
I have got everything going again with the help of a hairdryer, however PHlocation always shows as plugin disconnected, I enabled the developer options and it crashes at the end of loading every time.
I did a file restore of the whole HS3 directory back to 10 days ago and after a reboot it still does exactly the same thing, so very confused. Any pointers?
I also get this on HS3 startup;
05/03/2018 10:46:21 ~!~Error~!~Calling HSEvent in plugin PHLocation, Instance :Object reference not set to an instance of an object.Startup Complete, 1 errors detected, check the log for more information.
