Originally posted by dcorsus
View Post
OK, this seems to indicate that the plugin is activated and the config button is now working or not? Maybe a screen shot can help. Assuming the "DLNA Config" button on top of your screen works you should see a screen as attached. The first step you need to do is click on "Add" for those devices that you want HS to control. Once you click "Add", the button for that device should disappear and there should now be a button that allows you to set specific configurations only to this device. The button is "Config". So once you click add, the device is automatically added and activated. If it shows deactivated, it is either because you didn't add it or you deactivated the device in the HS Setup page. So the status should show actived on-line or activated off-line. If off-line, it means that the plugin cannot ping it, so it might have gone off-line since it was discovered and now. The save button is only used when you change the name of the zone and you want to save it.
I assume the ### of old and new are different or are they the same? Not sure why the discovery would find a different IP address. How frequent do you see this in your log? Every ?? minutes?
What OS are you running this on?
What would help is for you to turn the debug flag on in the config page, (see screen capture) and email the log file in a private email.
Sorry for not having found the time to write documentation, it is on my list of things unless there is no interest in the plugin ....
On a different note, how do you like the Kodak EasyShare Digital Picture Frame? I wasn't aware there were DLNA enabled picture frames out there, I'm definitely going to look into this. What was not clear to me, did you get anything to work via the plugin?
Dirk
Dirk
