Can it be this?
kinect stop working suddenly
the empty optional words are probably a formatting problem in the HS logs, could you turn on the "log to file" option at debug level from the kinect config page, then restart the plugin and send me the Logs/Kinect.txt file
I still suspect the WeatherXML VR commands to be the problem, so you can try to completely delete the "WeatherXML VR Kinect 1" event and then restart the kinect plugin to see if that change anything
I deleted the weather XML event and now it started working. Is it the way its written the problem?
Sent from my iPad using Tapatalk HDHector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by spud View PostI guess so, I will try to reproduce the problem this weekend.Hector
Win.2003 OS, HS3
Originally posted by Rotech View PostSpud, have you got the chance to chk this out by any chance?
did you try to remove the location part of the VR string and/or using only one of the string, as Jeff suggested here:
http://board.homeseer.com/showthread...17#post1193617
