The ACRF2 had a nice feature that you could offset the rf-in x10 address by an offset I used 15,, why one would use an offset greater than 15 escapes me.. Back to the feature basically in my case as I said I added an offset of 15 , so A1 would become a16 , a2 - a17 , a3 -18 and so on,, as one sees the biggest benefit is that all the lower addresses can be used for X10 PLC addresses and the plus 15 lets one process the X10 RF as if it was a separate 256 addresses that did not get retransmitted to the X10 PLC.. Another benefit is it makes it easy to determine if a device is X10 PLC or X10 RF ,, PLC would be x1 - x15 and rf becomes x16 -x30,, neat...
I'm hoping that maybe in a future update of the RFXCOM HS3 plug maybe you could add this feature..
Dave
Dave
