Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion
Old October 12th, 2013, 10:02 AM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Seer Master
What to buy rfxtrx433, rfxlan, rfxtrx315
I just don't know why and how to chose one over the other.
Any input is appreciated.
I want t o replace my w800 which has a shorter than desired range.
Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
Old October 12th, 2013, 12:43 PM
b_weijenberg b_weijenberg is offline
OverSeer
RFXtrx315
- receives US X10 (310MHz) sensors
- or US Visonic PowerCode (315MHz) sensors
RFXLAN
- receives many 433.92MHz sensors (mainly European)
- transmits 433.92MHz signals to control European devices.
See also the Will Support list on the RFXCOM web site
RFXrec433
- receives a lot more 433.92MHz sensors
RFXtrx433
- transmits 433.92MHz signals to control many many European devices.
Older RFXCOM USB versions:
USB 310MHz receiver for US X10 only
USB 433.92MHz receiver for:
- European X10
- Oregon Scientific
- OWL CM113,CM119
- Electrisave
- cent-a-meter
- HomeEasy
- Chacon
- NEXA
- KlikAanKlikUit
- ELRO
- RFXSensor
- RFXMeter
- KD101 smoke detector
- ATI Remotes
Last edited by b_weijenberg; October 12th, 2013 at 03:24 PM. Reason: old USB version added
Old October 12th, 2013, 01:07 PM
Seer Master
Re: What to buy rfxtrx433, rfxlan, rfxtrx315
Oh wow, i guess the euro market version does a lot more!
Too bad they dont make one that does both freqs. I wanted something that would do us x10 and oregon sci stuff. Doesnt look like they make such a monster yet.
Thanks for the input.
Sent from my GT-P1000 using Tapatalk 2
Old June 19th, 2014, 03:08 AM
ScottRennie ScottRennie is offline
Seer Deluxe
I currently have an RFXLAN with LAN i/face and HS2.
When I upgrade to HS3 I would like to control my Somfy RTS blinds - is there an upgrade to the RFXLAN available?
If not, can I run an RFXLAN & an RFXtrx433E at the same time? The range is going to be an issue if I can only use the USB device.
Regards
Scott
Old June 19th, 2014, 04:23 AM
OverSeer
The RFXLAN cannot be updated but can be used together with the RFXtrx433E.
If the Homeseer system is not on the right place for RF you can connect the RFXtrx to a RaspberryPI and install socat or ser2com. With this you can connect the RFXtrx over LAN.
Old June 19th, 2014, 05:01 AM
Seer Deluxe
Cheers Bert,
Is there going to be an upgrade to RFXLAN or is it obsolete for new features already?
Old June 19th, 2014, 05:11 AM
OverSeer
RFXLAN has never had updates for the receiver/transmitter firmware because it does not have flash memory that could be updated by the user.
The RFXLAN Ethernet controller has user up-gradable firmware to flash TCP/IP or xPL firmware.
HTML code is Off
Can RFXCOM read tire pressure using a RFXtrx315? NeverDie RFXCOM Plug-In (3P) 7 October 3rd, 2013 12:11 PM
NEXA door sensor with rfxtrx433 kolaf RFXCOM Plug-In (3P) 3 July 31st, 2013 03:18 AM
Issue with a RFXLAN and X10 JML RFXCOM Plug-In (3P) 6 January 19th, 2013 07:16 AM
Replacing USB Transmitter with RFXtrx433 JimBob RFXCOM Plug-In (3P) 6 October 28th, 2012 10:36 AM
RFXtrx433 and Irox ScottRennie Wireless Receiver & Transceiver Discussion 10 July 18th, 2012 03:08 AM
