Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old November 14th, 2017, 11:41 AM
sjeffrey sjeffrey is offline
Viewer
RFXtrx433e Reliability
Hi
Im having an issue where the RFXtrx433 keeps on dropping off and the plugin can no longer speak to it. This seems to happen daily and i end up rebooting the pc to resolve the issue. The mrs is starting to get quite annoyed with me.
I have a Windows 10 Pro machine (fully upto date). Running the latest version of Homeseer. Ive updated the firmware on the RFX to the latest and also updated the windows COM drivers.
I get the following logged in home seer log.
36 (Open) error :System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_RFXCOM.clsRS232.Open()
Im wondering if i would be better putting the RFX into a PI an using ser2net and connecting that way, if it would be more reliable.
It used to be reliable so not sure what happened really.
hopefully someone will have a suggestion as to how to make it better?
thanks
stuart
Old November 14th, 2017, 11:49 AM
b_weijenberg b_weijenberg is offline
OverSeer
This problem indicates that the FTDI USB interface is frozen.
The source of the problem could be a spike on the USB power or an induction pulse on the USB cable.
A disconnect-connect of the USB cable or a restart of the system will reconnect the USB.
In many times the problem was solved by one of these:
- move the USB cable away from power cables,
- use a powered USB hub with a quality power supply,
- use a Raspberry PI with a quality power supply and ser2net
Old November 14th, 2017, 12:32 PM
Viewer
ok great, i will try moving the cable and running through a hub. Failing that shove it on the PI
Tags
rfxcom rfxlan rfxtrx433e
HTML code is On
RFXtrx433e gone from Homeseer store? bmil RFXCOM Plug-In (3P) 9 October 10th, 2017 05:26 PM
Reliability of HS3 Steve Q HomeSeer General Discussion Area 40 March 14th, 2016 05:20 PM
RFXTRX433E Ant Extension cheaha RFXCOM Plug-In (3P) 1 April 16th, 2015 07:39 AM
HS2 Reliability buffalogr HS2 / HSPRO 12 March 22nd, 2007 11:12 PM
KeypadLinc V2 reliability ballison Insteon Plug-in (Mark Sandler) 1 January 19th, 2006 10:46 AM
