Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion
Old October 10th, 2013, 03:09 PM
Dave Haig Dave Haig is offline
Seer Plus
AC-RF2 Processor Errors...
Running latest version of HS2 Pro and out the blue getting errors from my RFXSensor which has worked perfectly for years.
I deleted and recreated the devices many times and still the errors continue.
I replaced the RFXSensor with a new one and still the errors continue.
The devices show 'Communication Failure' and the Device Monitor shows 'Sensor Communication Failure'.
I can force a send of data from the sensor and the plugin immediatly complains about 'LastHeardEnvType202Time' even though it just heard from it.
The receiver seems to be working fine for all of my motion sensors, it is only having problems with the RFXSensor.
The condition started after my Z-Stick II would not allow me to add new devices, so I replaced it with a Z-troller.
I relearned all my devices set the correct device codes and the z-wave system went back to working correctly.
On or about the same time, this new problem surfaced.
The log throws errors as follows...
10/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType201Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 43200
10/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType202Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 43200
10/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on EnvSensorDevice2, LastHeardFrom. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 43200
10/10/2013 02:54:36 AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #4834 - RFX System Voltage Sensor;Reading;502
10/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType200Time. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 43200
10/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on EnvSensorDevice1, LastHeardFrom. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 43200
10/10/2013 02:54:35 AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #3324 - RFX Temperature Sensor;Reading;20.5
10/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType201Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 4320010/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType202Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 4320010/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType202Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 4320010/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on EnvSensorDevice2, LastHeardFrom. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 4320010/10/2013 02:54:36 AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #4834 - RFX System Voltage Sensor;Reading;50210/10/2013 02:54:36 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType202Time. The recovered value was 10/10/2013 02:54:36 and the save value was 10/10/2013 02:54:36Calculated diff of 4320010/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType200Time. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 4320010/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType200Time. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 4320010/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType200Time. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 4320010/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on EnvSensorDevice1, LastHeardFrom. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 4320010/10/2013 02:54:35 AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #3324 - RFX Temperature Sensor;Reading;20.510/10/2013 02:54:35 AC-RF2 Processor Notice: SaveDateSetting failed to save an accurate/recoverable date on Codes, LastHeardEnvType200Time. The recovered value was 10/10/2013 02:54:35 and the save value was 10/10/2013 02:54:35Calculated diff of 43200
Old October 10th, 2013, 04:18 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Have you tried restarting HS?
If you turn on debug looging in ACRF2 you might get additional information. I suspect this error message has meaning only to Jon Ort, though. Try sending him an email. His address is in a sticky on the ACRF2 forum.
HS3 Pro Edition 3.0.0.318
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old October 10th, 2013, 05:26 PM
Seer Plus
Thanks Uncle Michael,
I have reset the software, and the server, and the ports, and everything I can think of, to no avail.
I sent Jon an email and will hope for the best.
Dave
Old October 14th, 2013, 08:11 AM
Seer Plus
Solved
I beat this up for a couple days and could not resolve the issue.
I had to restore to a ghost image, prior to the errors.
Now, thankfully, all is well with the world!
How to use recieved RF by AC-RF2 processor uriel ACRF Processor (3P) 2 November 4th, 2010 11:00 AM
A new processor for the HomeTroller, why? fvhemert HomeTroller™ 19 July 16th, 2008 04:51 PM
AC RF Processor SteveD W800 RF Receiver (3P) 7 August 16th, 2005 09:41 PM
Processor temperature on HS remle HomeSeer General Discussion Area 2 May 29th, 2005 11:37 PM
Processor speed? Jim'll HomeSeer General Discussion Area 6 April 26th, 2004 04:53 PM
