Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion
Old October 14th, 2013, 08:30 AM
Dave Haig Dave Haig is offline
Seer Plus
Script To Monitor RFXSensor Heartbeat
I am using an W800RF32A receiver with an RFXSensor for reading pond water temperature.
As the water is temperature controlled, it rarely fuctuates more thatn half a degree.
As a result the last change value goes for days on end without updating and I have been having issues with the system not sending a heartbeat, I would like to watch things a little closer.
Can I via a script, update the temperature device perhaps with an hs.setDeviceLastChange statement when a heartbeat is received.
The log give me this...
10/14/2013 7:07:04 AM AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #1782 - RFX System Voltage Sensor;Reading;499
10/14/2013 7:07:04 AM AC-RF2 Processor --Processing Command from RF: RFXSensor Sensor #240 - RFX Temperature Sensor;Reading;18
But don't know how to use that as a trigger for issuing an update.
It sure would be nice just to look at the device and see that a heartbeat came in an hour ago, even though the value did not change.
433.92MHz RFXSensor Type-3 Jim'll ACRF Processor (3P) 3 November 14th, 2008 08:57 PM
RFXSensor Questions/help jackpod RFXCOM Plug-In (3P) 4 April 11th, 2008 01:17 AM
RFXSensor parity check flic Plug-In Development 2 August 13th, 2007 09:53 AM
RFXSensor based water level monitor Fuego Electronic Circuits and Hardware Modifications 18 May 22nd, 2007 04:21 AM
Motherboard Monitor script and script error htsource Script & Plug-In Library Discussion 7 October 20th, 2002 05:59 PM
