Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > WIIMote Plugin (3P)
WIIMote Plugin (3P) Discussions related to the WIIMote plugin by Spud.
Old August 26th, 2014, 12:54 PM
spud's Avatar
spud spud is offline
Moderator
Wiimote plug-in - Beta Testing
This plugin is designed to interface HomeSeer with a Wiimote (the primary controller for Nintendo's Wii console)
Please read the User Guide before installing.
Please report any bug.
Installation:
  • download the zip attached to this post and save it in the HS3 application folder in /updates3/zips
  • download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
  • go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the Wiimote line.
  • click the "Download and Install" button
  • enable the plugin from the "PLUG-INS > Manage" page
  • delete updater_override.txt from your HS3 application folder
Changes to v3.0.0.1:
- Added Rumble action
- Multiple instance support
Old October 12th, 2014, 10:40 PM
steveng steveng is online now
Seer Plus
Spud,
So I am giving this a try, but I get
[IMG]http://forums.homeseer.com/attachment.php?
While tring to run the WiiPair.exe
Steven G
Old October 12th, 2014, 11:00 PM
Seer Plus
False Alarm!
I updated the bluetooth drivers and it works perfect.
Steven G
Old October 13th, 2014, 07:59 AM
spud's Avatar
Moderator
Originally Posted by steveng View Post
False Alarm!
Steven G
ok, let me know if you have any problem.
and please give me some feedback, I didn't get much for this plugin so far.
Old October 13th, 2014, 10:44 PM
Seer Plus
Spud,
Everything seems to be working great, I am trying your XBMC PI and using the wii as a remote control for it
I have found for me the position is not very useful as I tend to aim it up or straight alot and not think about it so I get false actions, if i just use the buttons for actions it works perfect.
Have not tried yet, but I assume you can use multiple Wii remotes (instances)?
Steven G
Old October 14th, 2014, 11:05 AM
spud's Avatar
Moderator
Spud,
Steven G
Thanks for the feedback!
Of course using the position is not mandatory, using the buttons only, work just fine. Adding a condition on the the position is just a way to use the same button to trigger different events.
The current version of the plugin (3.0.0.0) does not support multiple instances (multiple remotes), but it is something quite easy to add.
Old October 14th, 2014, 11:19 AM
kideon kideon is offline
Does this work with remote instances?
Old October 14th, 2014, 11:23 AM
spud's Avatar
Moderator
Yes it does support remote instance
But right now it only support one instance (remote or not). I will add support for multiple instances soon
Old October 14th, 2014, 02:14 PM
Sounds good. Wonder if it would be possible to use the speaker for anything like announcements..
Old October 14th, 2014, 03:32 PM
spud's Avatar
Moderator
I can easily add actions to control the rumble and LEDs (Note that you can already controls the LEDs using HS devices), but using the speaker is technically more challenging.
Old October 16th, 2014, 09:08 AM
spud's Avatar
Moderator
in version 3.0.0.1 available on first post of this thread, I have added support for multiple wiimotes (using multiple instances of the plugin) and a Rumble action:
Old June 9th, 2015, 12:50 AM
kenrad's Avatar
kenrad kenrad is offline
Spud having issues with the wiipair.exe connecting to my wii remote. it find it but then wont add it to bluetooth devices seethe screen shot need a little help here thanks
Ken
HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Old June 9th, 2015, 12:52 AM
kenrad's Avatar
does this support multiple remote instances yet
Cheers Ken
Old June 9th, 2015, 08:31 AM
spud's Avatar
Moderator
Ken
Have you tried to run wiipair.exe as Administrator?
the pairing process is a little picky, I frequently have to do it several times before it works correctly.
yes it supports multiple instances, I haven't actually tested a remote instance but it should work as well.
Old June 10th, 2015, 12:19 AM
kenrad's Avatar
I have tried running it as administrator and I still get eh same results that the user is no authenticated any ideas I can get it to pair with windows directly but like you stated in the users guide it doesnt stay long
Old June 13th, 2015, 03:34 PM
spud's Avatar
Moderator
Never saw this error before. What kind of wiimote do you have?
anyway, I'm going to try to use a different bluetooth library to build the WiiPair.exe and see if that can fix some of the problems.
Old June 17th, 2015, 03:00 PM
kenrad's Avatar
Spud,
I'm not sure what you mean about what kind of remote I have. it would be nice to get these to pair permanently could be a great addition to my setup
Old June 17th, 2015, 03:04 PM
Moskus's Avatar
Moskus Moskus is offline
Cool idea! I'll see if I can find my old Wiimote.
HSPro 3.0.0.368, Z-NET with Z-wave plugin 3.0.1.136, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Are you Norwegian (or Scandinavian) and getting started with HomSeer? Read the "HomeSeer School"!
Old June 17th, 2015, 03:05 PM
kenrad's Avatar
The plugin works awesome I just cant get my wii remote to stay paired to my PC
Old June 17th, 2015, 03:22 PM
spud's Avatar
Moderator
Spud,
is it the original wiimote or the wiimote plus or another version?
I have only tested wiipair.exe and the plugin with original wiimotes, so there may be some slight differences...
Tags
game controller, remote, wii, wiimote
UPB Plug-in - Beta Testing spud UPB plugin by Spud (3P) 102 December 30th, 2017 11:57 PM
EnvisaLink DSC Plug-in - HS3 Beta Testing spud Envisalink DSC Plugin (3P) 52 May 30th, 2017 07:23 AM
IFTTT Plug-in - Beta Testing spud IFTTT (3P) 48 March 15th, 2017 07:23 PM
EnvisaLink DSC Plug-in - HS2 Beta Testing spud Envisalink DSC Plugin (3P) 102 October 31st, 2013 07:48 PM
DirecTV Plug-in - Beta Testing spud DirecTV for HS3 (3P) 0 October 1st, 2013 07:23 AM
