Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion
Old March 8th, 2015, 06:06 AM
Skinnez's Avatar
Skinnez Skinnez is offline
Outdoor RF led lights
Hi
I have a few of these led lights and are controlled by a remote. I was hopeful that the rfxcom would be able to give commands to them. For now I have them switching on and off with a relay in HS3, but I can't change the colours without using the remote.
Has anyone seen these or made any progress controlling them?
I'm not even sure of the frequency, I might take one of the remotes to bits but there isn't any literature I can find.
Cheers
J
TWLC IP65 Waterproof 50W RGB Colour Changing LED Floodlight with RF (radio frequency) Control
https://www.amazon.co.uk/dp/B00D19KR..._VAb.ub1F6KQ6D
HS3 3.0.0.368 Windows 8.1 Pro VM on a Mac-Mini VirtualBox
HSTouch, iTunes DAAP, Kodi, MediaController, PHLocation, Pushover, RFXCOM, UltraNetCam3, BLRadar, BLShutdown, weatherXML, Random, Jon00 Network Monitor, JowiHue, Nest, UZB-1
700+ Devices, 400+ Events & lots of scripts.
Hyper-V 2012 virtual domain - 3 VM's
Server 2008 R2, Server 2012, Exchange 2013..
Old March 8th, 2015, 08:48 AM
Skinnez's Avatar
The chip inside is a PT2264
Princeton technology corp.
Old March 8th, 2015, 12:15 PM
mfisher's Avatar
mfisher mfisher is offline
Sorry to say that I don't think these will be compatible with the RFXCOM transceivers. According to the Princeton datasheet for the PT2264 encoder (below), the devices utilize RF frequencies between 30-150kHz, while the RFXCOM devices run in the 433mHz range.
Princeton PT2264 Encoder IC datasheet:http://www.princeton.com.tw/Portals/...t/PT2264_1.pdf
Best regards,
-Mark-
Old March 8th, 2015, 01:59 PM
Skinnez's Avatar
Thanks. I googled it myself and that's pretty much how I read it.
I was hoping I'd read it wrong and someone knew better.
I suppose I could hook up an rfx relay with a solenoid that pushes each button
Cheers
J
Old March 8th, 2015, 05:39 PM
Pete's Avatar
Pete Pete is offline
Yeah here have them switching on and off via an automated switch. They do lose their memory and go to default when they are powered on.
I did purchase new holiday LED lighting at the end of 2014 that is programmable and noticed that I could program the lights and power it off and on and the memory of the program stayed which was a good thing.
The alternative (wired or wireless) is using the old RGB lighting standards with digital controls (say running on an RPi).
Automator
Old March 8th, 2015, 05:52 PM
Skinnez's Avatar
That was the first thing I checked when I got them, that they remembered their setting when power was cut. It did say that they had a memory when I purchased them. Would be hopeless switching them on with HS and then have to change the colour with the remote. They are OK, let's see how long they last outside.
It's a shame no one does an outdoor colour led floodlight, say z-wave, that HS can control.
Outdoor lights only after dark oregonbob HS2 / HSPRO 10 January 1st, 2013 04:30 PM
X10 on turns lights on, missing off leaves lights on. Help! richtj99 HS2 / HSPRO 12 July 2nd, 2007 01:03 AM
Turn off outside lights after an Alarm event ONLY if lights are supposed to be off bradhs HS2 / HSPRO 1 April 27th, 2007 03:16 AM
X10 Received D1 D All Lights Off doesnt set all D lights jeremylaurenson HS2 / HSPRO 0 October 28th, 2006 12:11 PM
ALL LIGHTS OFF, All lights on all house codes. Rupp HomeSeer General Discussion Area 4 March 23rd, 2006 04:27 AM
