Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > WIIMote Plugin (3P)
WIIMote Plugin (3P) Discussions related to the WIIMote plugin by Spud.
Old November 11th, 2015, 07:23 PM
kenrad's Avatar
kenrad kenrad is offline
wii pair exe
Spud, any chance of taking a look at the wiipair.exe I was unable to get it to work and at one time you were discussing an update to the wiipair.exe is this possible. I loved the plugin but stopped using it becuase of pairing issues
Thanks Ken
HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Old November 11th, 2015, 09:09 PM
spud's Avatar
spud spud is offline
Moderator
well I had a look a while ago, and I couldn't make it work very reliably, this paring thing is very confusing...
I will have another look
Old November 12th, 2015, 04:28 PM
spud's Avatar
Moderator
after some more testing, here is a method that works very reliably for me, and makes the pairing permanent
1. Prevent windows from searching windows update for new drivers: http://www.storelocatorplus.com/skip...indows-update/
The reason to do this is that searching windows update can take a very long time, and in this case it seems to mess up the pairing process with the wiimote.
2. Start WiiPair.exe (You may have to temporarily disable your AV, I had to)
3. Press the red sync button inside the battery-department of the Wiimote and HOLD it.
4. Wait until WiiPair.exe finds your wiimote and until Windows finishes installing all necessary drivers, you should hear the standard windows driver sound when it's done
5. keep holding the red button
6. starts the Wiimote plugin, if everything is ok, it should connect to your device and the wimote should rumble for 1 second, you can then release the red button.
Schlage Lock Won't Pair macrho HomeSeer Z-Wave Plug-in 23 May 30th, 2015 04:33 PM
Stereo Pair Problem jkproctor PI-SonosController (3P) 4 December 14th, 2013 01:28 PM
Un-pair Re-pair WDTC-20 mistrb HomeSeer Hardware 0 December 12th, 2013 11:50 AM
12volts over twisted pair? sponnath Electronic Circuits and Hardware Modifications 7 March 16th, 2008 08:34 AM
