Is the Homeseeer server down at the moment ?
    I currently cannot connect via the Homeseer server and Alexa is not responding to any of my Homeseer device commands. Is there a server down at the moment.
    It's working here in Alabama and so is my Dot.
      Thanks Rupp. Still nothing at my end.
        Alexa hasn't been able to control hs3 devices all morning here in MD
          Same problem here.
          "Trigger" events seems to work. But not the simple ones. On the Alexa page, devices are appearing "Offline" even after refresh discovery.
            It certainly seems like there's a problem with at least one server. Seems like others are experiencing similar problems. Can you confirm if you are having problems logging into HSTouch via myHomseer.
              Huh..Problem there too. Getting an "Unable to connect, click OK to retry" error. Trying through Android phone app.
                Am I to understand that your local HomeSeer setup depends on an external server?
                Sent from my SM-G955U1 using Tapatalk
                  Myhs remote access is working fine for me.
                  Alexa app doesn't show the devices as offline. But when I issue commands to the echo, it says the device is not responding right away. Tested all hs devices and same result. Controlling other skills like hue work fine, so it is specifically an issue with hs devices
                    All back to normal this morning for both Alexa basic and HSTouch this morning!
                      Hi Gary,
                      No. My local core usage was fine (One great reason to have HomeSeer!). But basic Alexa commands and HSTouch android remote control use the MyHomeSeer cloud service which is where the problem seemed to stem from.
                        I checked all the servers and the logs and could not see anything obvious. I restarted the service on the connection server. Let me know if anyone is still seeing an issue.
                          IT was down yesterday afternoon for sure (KC area)
                          I know when HSTouch APP prompts me to log in the servers are down. Agree with "glad my home isn't cloud based", I could still control home from my IPHONE, just not away from home.
                          It's concerning that Rich didn't see anything with the servers because most likely the problem will return. With Alexa Control and the recent Leviton announcement HS needs to get a handle on this Gremlin.
                            Yep, here I have a purchased domain, have let's encrypt ssl certs and host a reverse proxy in my home. I https wrap my main UI, and tcp forward HSTOUCH from our phones on the outside. The only component for me that still relies on myhs are my amazon dots. Eventually I would like to develop a skill that cuts myhs out of the loop.
                              So it's ok now for anyone who could get Alexa to respond?
