This is going to be the second sensor I add to my system, the other is a ZWN-BPC ceiling sensor, neither is reporting battery or anything. Are there specific things I need to do to add sensors?
Monoprice garage tilt sensor not reporting - Solved!
Originally posted by dannieboiz View PostThis is going to be the second sensor I add to my system, the other is a ZWN-BPC ceiling sensor, neither is reporting battery or anything. Are there specific things I need to do to add sensors?
so I learned a few things troubleshooting this.. mainly from reading the forum
Once paired, stick the sensor back on the garage, open and close it a few times while I optimize the zwave network it'll update.
If that doesn't work, close the garage, remove the battery, plug it back in, close the tempared switch, run the garage. It all seems to work now.
