Using HS v 2.2.0.66
The checkmail script is hanging from time to time. Looking at the threads page I find multiple instances of CheckEmailPOP_V3_HS2.vben in a "running" state. Eventually HS crashes. Nothing appears the logs, other than the standard info message that the script is being run.
If I try and terminate HS normally the shutdown message appears in the log but HS doesn't quit. I have to terminate the process using the task manager.
I suspect this might not be the POP script but could be something wrong with this HS build.
