I'm trying to use the UltraGCIR plugin to display the power status of my DVD player. I have an iTach IP2IR connected to my DVD player via the GC-SV1 cable (senses the video out signal to determine if the device is on or off). I have the iTach connector set to "Sensor In".
The plugin creates a device for this connector correctly but the status does not change when the DVD player is turned on/off. I see the light on the iTach turn on/off in sync with the DVD player so I'm pretty sure I have it hooked up correctly.
Does this plugin support the GC-SV1 device? If so, any ideas what I'm doing wrong?
Thanks in advance!
Thanks in advance!
