Hi Mark;
It appears the updater is broken once again it states that the insteon update failed.. and HS3 now deletes the updates3 folder so I can not manually update the insteon plugin.. I don't thing it's your plugin only because your plug worked fine until I loaded the HSZIGBEE plugin after that your software appears not to be able to talk to the insteon hub... With the last several HS3 issues it's looks to me like Homeseer is trying to go out of business !! HS3 has been such junk over the past 3+ years ,, I'm starting to go over to OH it's free and just seems to be better supported.. I do want to thank you for your great plugin and fantastic work over the years ,, Homeseer needs a lesion from you and several of the fine 3rd party programmers that stand behind there software unlike Homeseer , that don't even show a presence on there own message board except to try to suck new users in with software that isn't even out yet (Like the new mobile ,, right , like that will ever work the base program doesn't work how do they expect mobile to work !!! Sorry for the rant but it's been over 3 years and they still have not fixed the power failure corrupting the database issue,, as well as many other issues... The lastest is they are saying the issue has been fixed or looking the bug reports so nobody is aware of the issue.. I've been using Homeseer since HS 1.xx (Never got completely fixed.) 2.xx dido and now 3 which they just don't seem to care about, I'm betting there working on HS 4.xx that's how they operate.. I't a bummer they don't understand they been knocked of the top 10 HA software lists and there message board appears to have less and less people visiting it...Once again thanks for all the fine work, I know it has not been easy insteon appears to come out with a lot of stuff that appears not to be thought out very well or just don't work as they stated..
