I originally had a 2414U (PLC) which I had to switch over to a 2413U to use the newer plugin. I have 43 switches, 25 of them have Version 6.0 but are not dual band. Before when I had the 2414, it was communicating flawlessly with my 18 switches which were located over 100 feet away from the interface. I also have over 60 X10 switches and the communications were flawless. (I was using a CM11a for communication.) Since I changed over to the 2413U (Dual Band), it seems like sometimes the switches have a little delay when I turn them on or off from the Homeseer system. For example, when I click a switch off, I have an event to to off three other switches. It seems like it should be within a second to switch them all off at once, but they turn off one at a time. (With the old PLC, they would run instantly, and altogether.
The message quality is from Good to Excellent on all of the switches but I have some comm reliability issues where some of the switches are in the 60-70% range. I am thinking that I need to get another Dual Band switch to possibly increase the signal strength, but would that be all I need? Would it be advisable to reset the new interface?
Is there any ideas?
Steve
Is there any ideas?
Steve
