Go Back   HomeSeer Message Board > Internet or Network Related Plug-ins > Internet or Network Discussion
Old October 24th, 2016, 05:54 PM
Hallager Hallager is offline
Viewer
HomeSeer as a UI layer. receive and send ASCII and JSON
Hello everybody, I'm new here and am looking forward to working with HomeSeer
I've got a client who wants a plugin for HomeSeer. I know nothing about HomeSeer and he is aware of it.
I seek your help to keep me on the right path. The second problem is that I can not VB.NET but C# I am good at. It should not be a problem,
I can probably figure it out. but if you have the choice to help me in C# I appreciate it.
The task is that I need to use the HomeSeer as a UI layer.
I need it to receive and send two languages ASCII and JSON.
It will receive commands that will then switch state of a device in the UI.
If you switch state of a device in HomeSeer, it should then send ASCII or JSON back.
I am aware that HomeSeer can receive JSON so here are some of the problem solved, I hope.
I hope you can help me to get started.
Best regards,
Johan
Old October 24th, 2016, 07:40 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
HS won't be able to just send JSON data based on a value change. You would have to invoke it from the client side. A plugin implements a callback where every device change is picked up immediately by the plugin. You also get much more flexibility out of a plugin with your own actions, triggers and conditions. Also, you can encapsulate your web ui in the plugin itself.
Just something to think about.
Sent from my SCH-R970X using Tapatalk
Old October 25th, 2016, 04:52 AM
Viewer
rmasonjr Thanks for the answer.
Where would you say I have to start making a plugin in visual studio?
And do you know of some good tutorials? I've tried to find some without much success, a bit of code here and there.
Tags
ascii, json
JSON VS ASCII CPU loading? drozwood90 HomeTroller Zee 2 May 11th, 2016 10:19 AM
Can HomeSeer Receive And Send Keyboard Commands? aslamma HomeSeer General Discussion Area 8 March 27th, 2010 12:04 AM
IR Send/Receive connection to Homeseer pgpc1 UK/Europe 4 July 8th, 2005 08:29 PM
