Hi there... I apologize if this has been in a forum before but I couldn't find anything. I live in Canada and I'm running the latest Homeseer (windows) with the Omni and UPB plug-ins. I have recently added Alexa into the mix and it works great except with Thermostat values. All my temperatures are in Celsius (including the plug in configuration) and Alex is set to celsius and the English Canada language. However, Alexa doesn't seem to realize that the Omni setting is in Celsius already and reports a wrong measurement. As an example the house temperature could be in the mid 20's (hot) but it reports a negative number (20 degree Fahrenheit converted to celsius) I'm not sure what am I missing? Thanks for your help.
Alexa not reading Omnistat/Omni units correctly
GuestTags: None
It's hard to say if the issue is on the Alexa side or the HS/Plugin side.
For the OMNI plugin, Make sure your logging is set to DEBUG, then try to control the thermostat a few different ways. Then, check the OMNI Logs and let's see what is being sent to the panel.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by kpd View PostHi there... I apologize if this has been in a forum before but I couldn't find anything. I live in Canada and I'm running the latest Homeseer (windows) with the Omni and UPB plug-ins. I have recently added Alexa into the mix and it works great except with Thermostat values. All my temperatures are in Celsius (including the plug in configuration) and Alex is set to celsius and the English Canada language. However, Alexa doesn't seem to realize that the Omni setting is in Celsius already and reports a wrong measurement. As an example the house temperature could be in the mid 20's (hot) but it reports a negative number (20 degree Fahrenheit converted to celsius) I'm not sure what am I missing? Thanks for your help.
Start with Post #79 here for what the issue was we were experiencing....
https://forums.homeseer.com/showthre...=193584&page=4
-Travis
