Vista Alarm Plug-in Version 1.0.2
    Version 1.0.2
    Fixes
    - Arm Stay system status
    - Small change to prevent "Sending Display Faults command to alarm" from triggering too often
    New Features
    - Message trigger: trigger an event on a specific alarm message
    - Custom status and graphics per zone and for the system status device (98). See the device property page to change these settings.
    Installation Instructions
    You may install this new version over any existing version. The old version will be uninstalled.
    Note: When you start using the new Custom status/graphics, please remember to turn Off the option "Display device value string". It is not needed.
    Please post any issues with this version to this thread.
    Mark
    HS3 Pro 4.2.19.5
    Thanks alot Mark!
    Man, where is my AD2USB I have to write them an email. still no package.
      Mark,
      Very nice on the custom graphics, I'll test this new version over the weekend and post back results.
      Is the time based triggers and conditions using "Device Value Change" for events in the works?
      Nice work Mark this is a great plug-in.
      Cheers
      Jim
        Originally posted by jkarney View Post
        Mark,
        Cheers
        Jim
        Jim,
        The beauty of the custom value/graphics pairs I added is it allow you to use these values in the standard homeseer "device value change" trigger or the "device condition" to setup time based triggers and conditions; thus i don't need to mod the 'vista alarm' triggers or conditions.
        See the two samples below. In the first screen shot, i changed the "Fault" status to "Open" and it shows my value when i create the trigger. the second screen shot is similar, it just tracks the disarmed-ready time. Both of these scenarios are possible with the conditions as well.
        If you had something completely different in mind, please give me an example.
        Mark
        HS3 Pro 4.2.19.5
          Mark,
          This is exactly what I had in mind; I just looked and I selected the wrong device and did not see that you added this feature .
          I took another look after you made your post and realized I must be blind as a bat . Mark this feature for events is going to work out awesome.
          Thanks; I'll play this weekend and post back
          Cheers,
          Jim
            I installed the 1.0.2 version this weekend.
            I like it a lot.
            I do have an issue that i'm not sure if i'm doing it right.
            I'm trying to use one of the new trigger types.. (Vista Alarm Message Trigge)
            I have in my log:
            Event Log
            6/22/2009 1:23:28 PM
            Vista Alarm ****DISARMED**** Ready to Arm
            6/22/2009 1:23:38 PM Vista Alarm ****DISARMED**** Ready to Arm
            So i set up an event as follows:
            Trigger type: Vista Alarm Message Tirgger
            Keypad message:
            But the event never triggers
            Am i doing something wrong?
            Can i provide more information to help with this?
            Andrew B.
              Andrew,
              Have you tried other msgs? And not to ask a dumb question but is the event enabled?
              Mark
              HS3 Pro 4.2.19.5
                I was initially trying:
                DISARM SYSTEM or alarm occurs
                And when that didn't fire.. i made a new event with the
                And.. there are no dumb questions.. although i have been known to provide some dumb answers in my time..
                Yes.. the event is enabled.. (i went back and checked .. because .. well.. let's just say this has happened before)..
                I'm wondering.. do i need it in "quotes" such as:
                "****DISARMED**** Ready to Arm "
                I've tried with and without the trailing space.. (i copy it from the HS log into the event text box)
                Andrew B.
                  Spaces and quotes aren't necessary. I guess I'll have to check the code. It worked when I tested
                  Mark
                  HS3 Pro 4.2.19.5
                    Andrew,
                    i tried triggering on "ARMED *INSTANT* You may exit now" (without quotes) and it worked, but when tried triggering on "****DISARMED**** READY TO ARM", the trigger did not work
                    I am starting to think (based on the homeseer plugin SDK) that the "*" at the being of the msg may be a problem. HS maybe interrupting this differently.
                    Please try a standard FAULT msg and see if it triggers as expected.
                    Mark
                    HS3 Pro 4.2.19.5
                      Mark
                      Originally posted by mnsandler View Post
                      Andrew,
                      O.K...
                      I set up an event to trigger on
                      Fault 12
                      and it did work as expected.
                      However.. my event that is supposed to trigger on:
                      Did not trigger last night...
                      Summary:
                      Working Message Trigger:
                      Fault 12
                      Non-Working Message Trigger(s)
                      I'm intrigued by the what is causing the difference.
                      I'll work with you (as you have time.. i know you probably have a real life) to find a solution if possible.
                      Andrew B.
                        Andrew,
                        I think i figured out the problem...for what every reason, the .trim method is not removing all trailing spaces in all cases. there are probably at least two blank spaces after the non-working msgs that did not get removed thus the trigger did not get executed.
                        I fix this in 1.0.3
                        Mark
                        HS3 Pro 4.2.19.5
                          Andrew,
                          I fix this in 1.0.3
                          Thanks a lot Mark..
                          I love this plugin.. it has added tremendous functionality (and WAF) to the system...
                          I'll look forward to 1.0.3 when you have time.
                          Andrew B.
                            I really have not had time yet to test everything with this new release. I did have time to use the new custom value/graphics and the new "device value change" event trigger. These work awesome.
                            I will finish plug-in testing this weekend; I'll be sure to post results. I also visited the HomeSeer store today and purchased the plug-in; this plug-in is well worth the money.
                            I hope other HomeSeer users are looking to integrate the Ademco Vista alarm systems into there home automation systems. This is really a solid plug-in right out of the box.
                            Cheers
                            Jim
                              Cheers
                              Jim
                              Glad the new features are working for you. I have fixed the Message Trigger problem and will incorporate that into the next version.
                              If you have any other feature requests, let me know when you have time
                              thanks again for your support.
                              Mark
                              HS3 Pro 4.2.19.5
