Originally posted by teladog01
View Post
I looked at the traces.
There are 2 issues:
1/ you have errors on SetPlayMode, I'm going to simply suppress these because they are benign and are caused by some idiosyncrasies that Sonos has.
2/ There is an error on playing the radiostation. This I suspect is the players choking a little on all the actions been fired at them. When you play a radiostation, depending on your internet BW or other factors, it could take many seconds before the stream is actually buffered and playing. Not sure that the event in the log is the same action details as you posted above, you may have a logic conflict in your event (it fired at 5:37pm). I can see the Front Bedroom player being instructed to play a radiostation but than instructed I believe to link with itself while it is still trying to start playing the radiostation. Check the event for mistakes! The sequence I would follow for these events, assuming the event only fires when the player is not playing, it is safe to FIRST link the players, that will cause all players in the link group to stop playing. Then set the volume and last what to play (radiostation, track ...) so the delay that might happen to start playing won't affect any other action in your event. If you program a "LINK" Sonos Command, make sure you don't have the Master player as part of your "to be linked" players.
Dirk
