Can I change Rfxcoms USB port via an event
    I have a second Rfxcom, which connects via a USB via IP connector. This works fine, but the software sometimes stops seeing the Rfxcom. Sometimes cutting the power to the USB over IP adapter works (I have an event which power cycles the adapter when Rfxcom goes offline). But that doesn't always work. If I then to into the Rrxcom tab of that Rfxcom device, change the USB port to a different port, click done, go back in and change the USB port back to what it should be, it goes online again.
    So I would like to change this via a script or event. So if the Rfxcom goes offline, it'll reboot the USB over IP adapter (that part I have), then change the USB port, and a few seconds later change it back to the right port. (The Rfxcom in question always uses Com 6 so I know which port it is)
    Is that possible ?
