Guys,
I figure out how to solve this problem. First, go to your clock, bottom right and click "date and time propeties" then go to "time zone" and uncheck "Automatically adjust clock for daylight saving changes" make sure hit "Apply" and "OK" out. Then when you run the configure file for your tv_grab_na_dd, please choose the day light saving time of your time zone. In my case, I'm in CA I can choose either Pacific or Mountain/Pacific day-night time, I then choose "Mountain/Pacific day-night time" as my time zone. Once you do that in your configure file just follow Jeff's procedure then you should able to correct this problem. The bottom line is as soon as you uncheck the "Automatically adjust clock for daylight saving changes" then you are free to choose whatever you want and when running the config file it will run the one you choose in the tv_grab_na_dd. After all this, please make sure set your clock 1 hour behind to your current time since when you uncheck "Automatically adjust clock for daylight saving changes" it will move your clock 1 hour ahead before and you need to correct your current time.
hlkc
hlkc
