Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer IFTTT Channel Integration
HomeSeer IFTTT Channel Integration General Discussion of HomeSeer's IFTTT Channel
  #41
Old December 13th, 2016, 03:47 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
Note that you can also add the user/pass the headers, so they do not have to be in the URL (basic authentication headers).
Quote:
Originally Posted by baudi View Post
I figured it out. I had a space in the Maker URL between "phrase=" and the comand. Sheesh. It works after I remove that space. Sorry!
So it is possible to get a voice command from IFTTT to HS, but you have to put your user/password in the Maker URL. If you modify the IFTTT MyHS service to accept a voice command, that would be wonderful.
Thanks for all your help.
  #42
Old December 13th, 2016, 04:34 PM
baudi baudi is offline
Seer Deluxe
Are you talking about something like this?
http://user:pass@connected2.homeseer.com....
If so, that still exposes your username and password to whoever has access to the IFTTT Maker service (like the IFTTT administrators/developers).
David
  #43
Old December 13th, 2016, 07:04 PM
rjh's Avatar
rjh rjh is offline
I don't know what you are using to send the URL, but if you were using .NET you could set the headers with the user/pass then call the URL. If all you can do is enter a URL, you will have to add user/pass with the parameters.
  #44
Old December 13th, 2016, 08:43 PM
Seer Deluxe
I'm using the IFTTT Maker service. Everything you want to send is entered into the Maker URL. So there is no way to hide the user/password. Which is the problem with using Maker. Which is why we would like to have the IFTTT MyHS service allow voice commands.
  #45
Old December 23rd, 2016, 12:14 PM
tpchristian's Avatar
tpchristian tpchristian is offline
Seer Master
Rich,
Any luck yet getting the voice command action on IFTTT?
-Tom
- Tom
HSPro/Insteon
  #46
Old December 23rd, 2016, 12:55 PM
rjh's Avatar
rjh rjh is offline
It is all coded and ready to test. We will be testing next week. Will update you when we have it working.
Quote:
Originally Posted by tpchristian View Post
Rich,
-Tom
  #47
Old December 30th, 2016, 06:58 PM
rispence rispence is offline
Viewer
IFTTT Dim a Homeseer Device Feature Request
can I get the capability to use a custom variable in the 'dim a device' action?? I want to use my google home to dim a device to a specific level (1-100) using 'Say a phrase with a number' trigger. Thanks!
  #48
Old February 17th, 2017, 04:00 PM
Seer Deluxe
Quote:
Any news on the this? Sure would be great.
  #49
Old February 17th, 2017, 07:16 PM
rjh's Avatar
rjh rjh is offline
I assume you mean the IFTTT support? This has been out for a few weeks, just use the text ingredient.
  #50
Old February 17th, 2017, 07:56 PM
Seer Deluxe
Great. Thank you.
  #51
Old April 3rd, 2017, 11:25 PM
sniogi sniogi is offline
Viewer
Google Home --> IFTTT Dim commands not working with text ingredient
What command are you speaking to google home to dim a light? The command I speak directly to HS3 on my PC ("set kids room light to fifty percent") works fine. The same command to IFTTT via google home fails.
Turn on and turn off IFTTT commands work fine. Only dimming fails.
My log shows:
"Info: Heard: set kids room light to 50" [ What I actually said to Google home was: "OK Google, tell homeseer set kids room light to 50 percent"] The IFTTT recipe is "Tell Homeseer $" the [textfield] ingredient is what is sent to homeseer
The next log entry is:
"TTS Speak (json:"
then nothing...
When I issue a turn on/off command ("Turn kids room light on") the next entry log is:
"ASR: Device voice command: turn kids room light on" And this works fine.
Many thanks in advance!
Last edited by sniogi; April 4th, 2017 at 10:19 AM. Reason: added information for clarity
  #52
Old June 20th, 2017, 07:56 AM
spud's Avatar
spud spud is online now
Moderator
There was some protection on the properties, I have put in a fix in build 304 which is posted here:
http://forums.homeseer.com/showthread.php?t=181241
To set them and trigger events, do this:
http://IP/JSON?request=setdeviceproperty&ref=####&property=NewDevString&value=STRING_VALUE
http://IP/JSON?request=setdeviceproperty&ref=####&property=ChangedValueORString&value=TRUE
Rich,
The HSEvent callback is still not called in my plugin when those json urls are called.
HTML code is Off
Feature request.. dem5867 BLBackup (3P) 1 November 22nd, 2015 08:55 PM
HS3 feature request JimBob RFXCOM Plug-In (3P) 3 June 3rd, 2014 07:40 PM
EZFlora Plugin Feature Request and EZIOxx Plugin Request hurry4it Insteon Plug-in (Mark Sandler) 30 March 8th, 2012 07:18 PM
CCE Feature request langenet HomeSeer Current Cost Envi Plug-in 1 November 22nd, 2011 12:13 PM
HS2.0 Feature Request MeSteve HS2 / HSPRO 8 August 21st, 2006 05:32 PM
