Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer IFTTT Channel Integration
HomeSeer IFTTT Channel Integration General Discussion of HomeSeer's IFTTT Channel
Old September 26th, 2017, 09:13 PM
Richel Richel is offline
Seer Master
Weird issue with IFTTT trying to create Homeseer applet
I am trying to create a new applet with the "IF" part being a Homeseer device is turned off. When I select that function, no devices load, it just hangs on "Loading..." On the other hand, if for the "IF" part I select a Homeseer device is turned on, devices load instantly. Anyone else seeing this issue? The applets that I have already created have been working fine. I am presently on HS3 Pro Edition 3.0.0.365 (Windows).
Elliott
Old October 13th, 2017, 03:42 PM
jfla jfla is offline
Seer Deluxe
Same for my event, just " Loading" , i can't select an event form IFTTT
My system:
Current Date/Time: 13/10/2017 21:42:01
HomeSeer Version: HS3 Pro Edition 3.0.0.372
Operating System: Microsoft Windows 10 Famille - Work Station
System Uptime: 1 Day 17 Hours 27 Minutes 28 Seconds
IP Address: 192.168.50.53
Number of Devices: 450
Number of Events: 138
Available Threads: 200
Enabled Plug-Ins
2.0.35.0: BLLAN
1.0.3.0: BLShutdown
2.0.10.0: BLUSBUIRT
4.8.5.0: BULLET
0.0.0.26: drhsIpPlugIn
3.0.0.64: mcsXap
3.0.0.14: NetCAM
3.0.1.90: PHLocation
30.0.0.35: RFXCOM
5.0.2.0: SCREPOSITORY
4.0.0.4: THERMOSTAT
3.0.0.44: X10
3.0.1.148: Z-Wave
Old October 13th, 2017, 06:15 PM
Seer Master
Apparently, this is an intermittent issue. Everything is working for me now, including using an event as a "then" component.
Old March 1st, 2018, 11:12 AM
Steve Q's Avatar
Steve Q Steve Q is offline
OverSeer
Richel, I am experiencing this same issue except with "device turned ON"; "device turned OFF" was working fine
I called HS3 Customer support and they reset my MYHS service account. I setup a new account. Now I cannot create any new recipies Triggered from HS3.
Can you check and see if you are able to create IFTTT recipies using HS3 device ON or OFF triggers.
thanks
Steve Q
Old March 2nd, 2018, 09:51 AM
Steve Q's Avatar
OverSeer
I fixed the problem. I discovered a device in HS3 that was not configured. It had no information at all. It was “unknown”. I have seen this before, I think it is simply a device that gets saved before any configuration info is added. When I deleted this device, IFTTT started working properly.
Steve Q
HTML code is Off
Changing IFTTT Credentials in Applet gnichols HomeSeer IFTTT Channel Integration 2 September 5th, 2017 09:29 PM
IFTTT applet failed Richel HomeSeer IFTTT Channel Integration 0 August 7th, 2017 10:11 PM
Cannot create new event applet Richel HomeSeer IFTTT Channel Integration 0 March 25th, 2017 07:33 AM
Access issue in IFTTT? Mario23 HomeSeer IFTTT Channel Integration 1 March 9th, 2017 03:28 PM
Weird behavior trying to create a virtual device in script... no controls mittelhauser HS3 Scripting 3 June 6th, 2016 11:53 AM
