INSTEON USB Interface (Dual-Band) 2413U not sending X10 direct dim commands to SwitchLincs and ToggleLincs. SmartHome says it should work, and told me to ask here to see if there is something in the way the modem is configured. It's working with Insteon devices, and can control the SmartHome switches, but only on/off commands. This modem is supposed to control X10 devices too and I really want to retire my CM11a. Any ideas?
What plugin & ver are you using? And did you enable the x10 interface on the hs setup/interface pageMark
HS3 Pro 4.2.19.5
Thanks for the reply.
I am using the included Insteon 1.4.2.0 interface plugin. I do have the X10 enabled, and then there is an "other" column which I also have enabled. In both cases the config tab opens the Insteon page, which I thought was odd. Is there is nothing to configure on the X10?
HS sees the interface on com port 8, and sends Insteon and X10. It just doesn't send direct dims/.brights to my SmartHome switches. They only respond to on/off commands.
Did you set the smartlinc option on the Devicetype associated with the x10 devices on the hs status page? The plugin does do any configuration for x10. It's all done via hs pagesMark
HS3 Pro 4.2.19.5
This is what it looks like. I think it's right. Keep in mind it sends the direct dim commands no problem with the CM11a. Same devices. Same events. They just don't work when using the Insteon Modem for X10. I tried the Insteon Plug-In, Insteon PLC-SDM 2414 Plug-in because it was listed as "newer" but it didn't work at all.
Device Type
SwitchLinc
Checked are:
Supports Status Requests
Uses SmartLinc Protocol
Uses Preset-Dim Dimming
This is what one of the devices looks like:
Reference ID 2064
Status 3 = OFF
Value 0
String
Supports Status True
Dimmable True
Misc Settings X-10 Preset Dim, SmartLinc
Can you post a detailed log of an attempt of the plugin sending a direct dim cmdMark
HS3 Pro 4.2.19.5
I talked to SmartHome, and they said the 2413U can and should send all X10, and if it didn't it had to be the software. I loaded the 1.5.3.0 version of this Plug-in, and sure enough it works. I send 50% to a SwitchLinc switch and it goes right to 50% just like it does with a CM11a. I'm on the 30 trial right now. I think it's interesting though that when I go to the updater, it sees the Plug-in for the PLM 2412 and the PLC-SDM 2414 as newer.
Originally posted by Isk82 View PostI talked to SmartHome, and they said the 2413U can and should send all X10, and if it didn't it had to be the software. I loaded the 1.5.3.0 version of this Plug-in, and sure enough it works. I send 50% to a SwitchLinc switch and it goes right to 50% just like it does with a CM11a. I'm on the 30 trial right now. I think it's interesting though that when I go to the updater, it sees the Plug-in for the PLM 2412 and the PLC-SDM 2414 as newer.
glad to hear everything is working. Let me know if you have any other x10 issues.Mark
HS3 Pro 4.2.19.5
