Can anyone tell me what this means:
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime1 noWrap align=left>7/4/2006 5:14:52 PM </TD><TD class=LOGType1 align=left colSpan=3>UPB </TD><TD class=LOGEntry1 align=left colSpan=8>Writing new Error log file - C:\Program Files\HomeSeer 2\Config\UPB Error Report.Log</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/4/2006 5:14:52 PM </TD><TD class=LOGType0 align=left colSpan=3>Error </TD><TD class=LOGEntry0 align=left colSpan=8>Initializing interface: UPB->Invalid or non-existant UPStart export file encountered, Preset Parse(4): System.IndexOutOfRangeException: Index was outside the bounds of the array. at HSPI_UPB.HSPI.ReadAndParseUPBExportFile(String& FileName)
</TD></TR></TBODY></TABLE>
I added a couple devices with UPStart and this is what I get when I restart HS. Note that when I simply restart the UPB plug-in, I get an error that the com port is in use, as if I hadn't terminated UPstart (which I had), so I simply rebooted the computer. And, by the way, as you would expect, the new devices are not imported into HomeSeer.
Hetre is the "UPB error report. log" file:
UPB Plug-in Error Log Generated 7/4/2006 5:14:52 PM
-----------*Error Message*----------------
Error: Invalid or non-existant UPStart export file encountered, Preset Parse(4): System.IndexOutOfRangeException: Index was outside the bounds of the array.
at HSPI_UPB.HSPI.ReadAndParseUPBExportFile(String& FileName) -- 7/4/2006 5:14:52 PM
--------*Initialization Log*--------------
7/4/2006 5:14:51 PM : Host System: HomeSeer*2.1.102.0
7/4/2006 5:14:51 PM : RegisterCallback Completed
7/4/2006 5:14:51 PM : Enter InitIO
7/4/2006 5:14:51 PM : Attempting to load UPStart export file: C:\Program Files\UPB\Designs\28540pch.upe
7/4/2006 5:14:51 PM : Parsing UPStart Export file...
7/4/2006 5:14:52 PM : Problem with UPB export file record: 4,0,0,70,8,100,2
7/4/2006 5:14:52 PM : ***:Invalid or non-existant UPStart export file encountered, Preset Parse(4): System.IndexOutOfRangeException: Index was outside the bounds of the array.
-----------*Pre-Error Log*----------------
--------*End Pre-Error Log*--------------
Also, it leaves the export file locked (so I could not attach it to this post without stopping Homeseer---even pausing the plug-in did not free up the file! This is after a fresh system reboot, so it cannot be anything UPstart did (or didn't do). And once I stop the HS service and exit the control program, I can, in fact, acceess the file, which is attached here in case someone (Oman??) has the time or knowledge to help. By the way, the line referenced in the error message is a line from one of my new devices. I'll go find my UPB export documentation to remember what that line istrying to do, but I think it is defining the receive links.
By the way, I am running HS 2.1.102 and UPB plug-in 1.0.2.4
Thanks for any help!
Pete
Pete
