First I have to say, I love this community. Great support from all the members.
My problem. I have two Venstar T1700 thermostats installed and running Insteon plugin 1.1.52.1 with HS 2.3.0.19.
I installed this script and it works beautifully for getting the data from the thermostats but it doesn't work when trying to set changes to the thermostats. The buttons on device screen don't do anything and have tried
in the Immediate Script Command to no avail.
Similiar to what others have seen, I see
with no other data when I start the Immediate Script Command. Is it passing the parameters correctly?
I can send logs but not sure what to filter to be helpful... maybe the Insteon address or just "TStat"?
Any help would be fantastic. Thanks!
"&hs.plugin("Insteon").ExtDev_TransmitToExternalDevice(TStat1, InsteonFlags, &H68, &H1) ' Cmd1 = Temp Up, Cmd2 = 1 (1 deg up)"
"10/16/2009 4:00:29 PM ~!~Insteon~!~ExtDev_TransmitToExternalDevice received transmit request:"
