Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > ISY Plug-in Beta (3P)
Old November 11th, 2008, 09:02 PM
jamesx0
Guest
Posts: n/a
Insteon Motion Sensor
It looks like the three groups for the motion sensor were added correctly by the plugin. It looks like the status isn't being reported correctly on the status screen. If the corresponding group is off, the status shows off. If the group is on, the status is blank. Attached is a text file with snippets of the log that shows the motion sensor sending both on and off commands for motion sensing.
I see that my password shows up in the debug level log file. Is there any way to encrypt the password from the beginning?
Insteon Motion.txt
Old November 11th, 2008, 11:49 PM
FrankR FrankR is offline
How did you add the MD? I tried using Add New Insteon Device in the ISY applicayion but nothing was added.
Old November 12th, 2008, 12:59 AM
bpwwer bpwwer is offline
Super Seer
I still don't have my motion sensor Of course, I'm not sure I'll be able to even use it when I do get it. But anyway. Looking at the log, it looks like all the events and status notices were processed correctly. I'm guessing that the issue is because I don't detect the device type properly. So that probably means that my generic device code isn't handling the on status properly.
I post a version in the next day or so. If it doesn't work correctly with the motion sensors, it will at least allow you to see what the device type is so can properly set up the device.
It ISY doesn't really support an encrypted password so there's not much point to the plug-in encrypting it, but my plan is to remove those specific debug messages.
Bob Paauwe
ISYInsteon Plug-in
Old November 12th, 2008, 08:38 AM
jamesx0
Guest
Posts: n/a
Hold the button on the back for 5 seconds. The LED will begin to flash. Press the button again and the LED will flash at a faster rate. Now you can manually add the motion sensor to the ISY.
Old November 12th, 2008, 02:48 PM
Thanks. I tried just about every combination except that one. I'll try it tonight.
What ISY firmware are you running, 2.6.8 ?
Plug-in 1.0.0.15 ?
Old November 12th, 2008, 04:10 PM
jamesx0
Guest
Posts: n/a
Plug-in 1.0.0.15 ?
Yes and yes.
