Old November 1st, 2009, 09:33 AM
jdls
Guest
Posts: n/a
Insteon motion sensor compatibility?
Wanted to check if anyone knows if the insteon motion sensor is fully compatible with HS? All I need it for is to trip when motion detected and that it will show in log. Dog sitter situation
Old November 1st, 2009, 10:16 AM
mnsandler's Avatar
Insteon Overlord
using the insteon PLM, hs plugin, and custom external script, the answer is yes. search the insteon lighting forum for more details
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
Old November 2nd, 2009, 12:08 PM
jdls
Guest
Posts: n/a
Thanks for the info Mn
