could you try a factory reset and post a detailed log of the 'Add' process
Insteon I/O Linc
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postcould you try a factory reset and post a detailed log of the 'Add' process
Code:7/22/2011 4:09:45 PM ~!~Insteon~!~Manual Add Selected 7/22/2011 4:09:50 PM ~!~Insteon~!~Confirm Add Device Selected 7/22/2011 4:09:50 PM ~!~Insteon~!~Set add job data : Name:New Lamp Module 7/22/2011 4:09:50 PM ~!~Insteon~!~Launching new BackgroundUpdate Thread with job type 20... 7/22/2011 4:09:50 PM ~!~Insteon~!~In BackgroundUpdate Thread... 7/22/2011 4:09:50 PM ~!~Insteon~!~Attempting to add Device 17.D5.81 7/22/2011 4:09:50 PM ~!~Insteon~!~Calling PLM_AddID for 17.D5.81 1 True 7/22/2011 4:09:50 PM ~!~Insteon~!~Sending command 02 6F 41 A2 01 17 D5 81 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True 7/22/2011 4:09:50 PM ~!~Insteon~!~..Got RF PLM Response 02 6F 41 A2 01 17 D5 81 00 00 00 15 7/22/2011 4:09:51 PM ~!~Insteon~!~Sending Insteon ID Broadcast for '17.D5.81' 7/22/2011 4:09:51 PM ~!~Insteon~!~Sending command 02 62 17 D5 81 0A 10 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False 7/22/2011 4:09:51 PM ~!~Insteon~!~..Got RF PLM Response 02 62 17 D5 81 0A 10 00 06 7/22/2011 4:09:51 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 18 D3 80 22 10 00 - Event: New msg for RF PLM, Src[17.D5.81] Dst[18.D3.80] {Ack/Dir} Cmd1: 10 Cmd2: 00 7/22/2011 4:09:51 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 07 00 36 87 01 00 - Event: New msg for RF PLM, Src[17.D5.81] Dst[--.--.--] {Brdcst} Cmd1: Device ID Broadcast/Set button slave, Type:0700 Firmware Ver:36 Cmd2: 00 7/22/2011 4:09:51 PM ~!~Insteon~!~Got controller/responder type broadcast for Insteon ID 17.D5.81 of type 0700, Firmware version 36 7/22/2011 4:09:51 PM ~!~Insteon~!~GetInsteonProtocol for '17.D5.81' 7/22/2011 4:09:51 PM ~!~Insteon~!~Sending command 02 62 17 D5 81 0A 0D 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False 7/22/2011 4:09:52 PM ~!~Insteon~!~..Got RF PLM Response 02 62 17 D5 81 0A 0D 00 06 7/22/2011 4:09:52 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 07 00 36 87 01 00 - Event: New msg for RF PLM, Src[17.D5.81] Dst[--.--.--] {Brdcst} Cmd1: Device ID Broadcast/Set button slave, Type:0700 Firmware Ver:36 Cmd2: 00 7/22/2011 4:09:52 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 18 D3 80 22 0D 01 - Event: New msg for RF PLM, Src[17.D5.81] Dst[18.D3.80] {Ack/Dir} Cmd1: 0D Cmd2: 01 7/22/2011 4:09:52 PM ~!~Insteon~!~Got Insteon Protocol Engine response from Insteon ID 17.D5.81, Protocol i2 7/22/2011 4:09:52 PM ~!~Insteon~!~Sending command 02 62 17 D5 81 1A 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False 7/22/2011 4:09:52 PM ~!~Insteon~!~..Got RF PLM Response 02 62 17 D5 81 1A 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 7/22/2011 4:09:53 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 18 D3 80 22 2E 00 - Event: New msg for RF PLM, Src[17.D5.81] Dst[18.D3.80] {Ack/Dir} Cmd1: 2E Cmd2: 00 7/22/2011 4:09:53 PM ~!~Insteon~!~Received STX 0x51 (Raw Insteon Rec):01 17 D5 81 18 D3 80 11 2E 00 01 01 00 14 20 00 20 00 3A 3F 00 00 00 00 - Event: New msg for RF PLM, Src[17.D5.81] Dst[18.D3.80] {Direct} Cmd1: EX Get/Set Cmd2: 00 01 01 00 14 20 00 20 00 3A 3F 00 00 00 00 7/22/2011 4:09:53 PM ~!~Insteon~!~Get Device Op Flags for '17.D5.81' 7/22/2011 4:09:53 PM ~!~Insteon~!~Sending command 02 62 17 D5 81 0A 1F 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False 7/22/2011 4:09:53 PM ~!~Insteon~!~..Got RF PLM Response 02 62 17 D5 81 0A 1F 00 06 7/22/2011 4:09:53 PM ~!~Insteon~!~Received STX 0x50 (Raw Insteon Rec):01 17 D5 81 18 D3 80 22 1F 02 - Event: New msg for RF PLM, Src[17.D5.81] Dst[18.D3.80] {Ack/Dir} Cmd1: 1F Cmd2: 02 7/22/2011 4:09:53 PM ~!~Insteon~!~Got Op Flags response from Insteon ID 17.D5.81, Op Flags 00=02 7/22/2011 4:09:53 PM ~!~Insteon~!~The device properties could not be read. Communication failure. The device was not added. 7/22/2011 4:09:55 PM ~!~Insteon~!~BackgroundUpdate Thread Complete...
please try the build on the following thread. there must be a bug in the ver you are running
http://board.homeseer.com/showpost.p...9&postcount=42Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postplease try the build on the following thread. there must be a bug in the ver you are running
That was it, as soon as I loaded the 1.5.5.16 Insteon plugin the I/O Linc was successfully added as a device to Homeseer.
Thanks Mark
Originally posted by hurry4it View PostThat was it, as soon as I loaded the 1.5.5.16 Insteon plugin the I/O Linc was successfully added as a device to Homeseer.
Thanks MarkMark
HS3 Pro 4.2.19.5
I have my garage door working with Mark's Driver and the 2450 iolink. I don't like how it functions as I'm not keen on polling the 2450 to get the current status. I really wish it could send HS a status update like the passive motion and door sensors. I'm going to keep playing with it, but Mark's current PLM plugin works. I may also put a controlled outlet on before the 2450 (same as the actual opener is plugged into) to act as a kill switch so the door can't be opened while I'm away. I'm willing to do some beta testing with you Mark if you'd like. Just shoot me an email. Tgreen [at] greentechmgmt.com
Cheers
Originally posted by TrevorG View PostI have my garage door working with Mark's Driver and the 2450 iolink. I don't like how it functions as I'm not keen on polling the 2450 to get the current status. I really wish it could send HS a status update like the passive motion and door sensors. I'm going to keep playing with it, but Mark's current PLM plugin works. I may also put a controlled outlet on before the 2450 (same as the actual opener is plugged into) to act as a kill switch so the door can't be opened while I'm away. I'm willing to do some beta testing with you Mark if you'd like. Just shoot me an email. Tgreen [at] greentechmgmt.com
Cheers
that said, i have noticed on my setup, the msg doesn't always make it back to the PLM. I think when the garage door opener is active (motor running), it generates noise on the powerline which probably blocks the msg.
thus polling may be required
so you may need to do a little testing on your setup. try disconnecting the door from the opener and open and close the door manually. do you see a msg generated from the iolinc in your hs log? You should. If not, there is other noise on the powerline blocking the msg.Mark
HS3 Pro 4.2.19.5
That would make sense, but even with it plugged in at my kitchen and the door sensor in my hand, I don't see the status in HS. If I wait, it will get there due to polling though. I even tried rapidly moving the contacts to and from each other to see if it was a broadcasting issue. Really wish there were config tools for the insteon products rather than the tap programming
I'll keep playing with it and let you know where I end up. Don't think this is you plug in being the redheaded stepchild.
Not sure this is a noise issue. I can send multiple on off commands while the door is in travel and it never seems to miss. I did the manual door opening and closing, the status light changes accordingly, but the status in HS only changes upon polling of the 2450. I think this is an insteon issue
can you remind me what version of the plugin & hs you are runningMark
HS3 Pro 4.2.19.5
Originally posted by TrevorG View PostThat would make sense, but even with it plugged in at my kitchen and the door sensor in my hand, I don't see the status in HS. If I wait, it will get there due to polling though. I even tried rapidly moving the contacts to and from each other to see if it was a broadcasting issue. Really wish there were config tools for the insteon products rather than the tap programming
I'll keep playing with it and let you know where I end up. Don't think this is you plug in being the redheaded stepchild.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postplease try the 'program device for homeseer' button on the device edit page. maybe the plm lost the record for the iolinc which is required for the plm to receive/process inboudn msgs, but not required to transmit msgs to the iolinc.
Is it something stupid like having the status closed when you first make connection? Idk, starting to run out of ideas
Odd, I did a re-read of the link table. There's now 16 links to unknown devices. Nothing to HS. Deleted all the links and they all came in again. The addresses do seem unlikely though. Must just be what Insteon load to their tables to "clear" them.
Anyways, I did the program for HS:
Now updating the link tables for your device...
Programming Insteon device ID 1D.02.81 link #1 of 1
Garage door closed:
Message Stat Count Percentage
1 Hop (Excellent) 1 5%
2 Hops (Good). 19 95%
3 Hops (Poor). 0 0%
Failed 0 0%
While door is in travel:
1 Hop (Excellent) 2 10%
2 Hops (Good) 18 90%
3 Hops (Poor) 0 0%
Failed 0 0%
That was using your comm testing tool
the 1 link is correct. the relay doesn't need a link because it operates on the same Group #
please display the interface links from the config page and make sure the iolinc is listed there as well.
please post a screen shot of the settings and op flags for the iolincMark
HS3 Pro 4.2.19.5
might be time for a hw reset on the iolinc and then a reprogramMark
HS3 Pro 4.2.19.5
