Problem with new keypadlinc switch
    I just received a new Keypadlinc today from Smarthome and tried to program the switch and received a message:
    8/27/2010 11:21:16 PM Insteon ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\Homeseer HS2\Config\Insteon Error Report.Log
    8/27/2010 11:21:16 PM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
    8/27
    8/27/2010 11:24:32 PM Insteon WARNING: The GroupLinkAddress INI section for device 25(16.E4.05) is corrupted. Please delete and re-add your device!
    8/27/2010 11:26:25 PM Insteon ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\Homeseer HS2\Config\Insteon Error Report.Log
    8/27/2010 11:26:25 PM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
    I noticed that when I programmed the switch (It is an 8 button switch) the switch programmed as a 6 button, so I changed it to 8 button and here is my Device Link Table:
    Device Link Table
    Link #1 Button A/Load has local control reporting to HomeSeer
    Link #2 Button B has local control reporting to HomeSeer
    Link #3 Button C has local control reporting to HomeSeer
    Link #4 Button D has local control reporting to HomeSeer
    Link #5 Button E has local control reporting to HomeSeer
    Link #6 Button F has local control reporting to HomeSeer
    Link #7 Button G has local control reporting to HomeSeer
    Link #8 Button H has local control reporting to HomeSeer
    Link #10 Button A/Load is controlled by HomeSeer using PLM Database Link #19 (Button Control Group) - On Level 100%, Ramp Rate .1 Sec.
    Link #9 Button A/Load is controlled by HomeSeer using PLM Database Link #254 HomeSeer 'All Devices Group' - On Level 100%, Ramp Rate .1 Sec.
    Link #11 Button B is controlled by HomeSeer using PLM Database Link #20 (Button Control Group) - Command: On
    Link #12 Button C is controlled by HomeSeer using PLM Database Link #21 (Button Control Group) - Command: On
    Link #13 Button D is controlled by HomeSeer using PLM Database Link #22 (Button Control Group) - Command: On
    Link #14 Button E is controlled by HomeSeer using PLM Database Link #23 (Button Control Group) - Command: On
    Link #15 Button F is controlled by HomeSeer using PLM Database Link #24 (Button Control Group) - Command: On
    As you can see, I am missing Button G and H. I tried to reread the links or program the links, but no good.
    Device Type: KeypadLinc V2 Dimmer
    Firmware Version: 36
    Comm Reliability: 100% (0 failed out of 62 cmds)
    Resume dim mode: False
    Default local on level: 100%
    Also this must be a new version switch 011c
    [Device 25]
    DeviceID=16.E4.05
    DeviceName=Hallway Keypad
    DeviceLocation=Insteon
    PollingInterval=0
    DeviceType=011C
    FirmwareVer=36
    DatabaseDelta=127
    LinksDownloaded=1
    EEValues=DefaultRampRate=31,ResumeDim=128,DefaultOnLevel=255 ,OnLEDMask1=0,OnLEDMask2=0,OnLEDMask3=0,OnLEDMask4=0,OnLEDMa sk5=0,OnLEDMask6=0,OnLEDMask7=0,OnLEDMask8=0,OffLEDMask1=0,O ffLEDMask2=0,OffLEDMask3=0,OffLEDMask4=0,OffLEDMask5=0,OffLE DMask6=0,OffLEDMask7=0,OffLEDMask8=0,NonToggleButtons=0,OpFl ags1=8
    GroupLinkAddress 1=19
    GroupLinkAddress 2=20
    GroupLinkAddress 3=21
    GroupLinkAddress 4=22
    GroupLinkAddress 5=23
    GroupLinkAddress 6=24
    Protocol=2
    LastContact=8/27/2010 11:54:14 PM
    NumLinks=15
    RecentDatabaseDelta=127
    Link 1=E2 01 0F D4 EF FF 1F 01 1
    Link 2=E2 02 0F D4 EF FF 1F 02 2
    Link 3=E2 03 0F D4 EF FF 1F 03 3
    Link 4=E2 04 0F D4 EF FF 1F 04 4
    Link 5=E2 05 0F D4 EF FF 1F 05 5
    Link 6=E2 06 0F D4 EF FF 1F 06 6
    Link 7=E2 07 0F D4 EF FF 1F 07 7
    Link 8=E2 08 0F D4 EF FF 1F 08 8
    Link 9=A2 FE 0F D4 EF FF 1F 01 9
    Link 10=A2 13 0F D4 EF FF 1F 01 10
    Link 11=A2 14 0F D4 EF FF 1F 02 11
    Link 12=A2 15 0F D4 EF FF 1F 03 12
    Link 13=A2 16 0F D4 EF FF 1F 04 13
    Link 14=A2 17 0F D4 EF FF 1F 05 14
    Link 15=A2 18 0F D4 EF FF 1F 06 15
    Any suggestions?
    yah, been having problems with 8btn kpls
    please do the following
    shutdown hs
    edit the insteon.ini and add the following to the device section for the new kpl
    GroupLinkAddress 7=25
    GroupLinkAddress 8=26
    then restart hs
    and use the program for homeseer btn to fix the missing links
    please let me know if this resolves the problem
    Mark
    HS3 Pro 4.2.19.5
      All links are back, but later this evening the 2 links were missing again. I reinstalled them and will check tomorrow to see if all is well.
      Steve
