Insteon PLM Plug-in Version 1.5 (license required)
    as i suspected. two options
    1. shutdown hs and change protocol=2 then restart hs
    or
    2. delete the device the from plugin and register and check that protocol=2
    not sure why the protocol wasn't read correctly
    Mark
    HS3 Pro 4.2.19.5
      ok
      some progress. shutdown HS, made protocol change and restarted. plug in options are there now, similar to your sample. after updating the links and settings, they properly reflected the settings of the IOLinc.
      when i see the results of a poll, the device status is reflecting the state of the sensor input. however, the HS device, on the status page, still shows it off all the time. what might be causing this?
      btw, are there potentially other features that i'm not seeing for similar reasons? for example, i still don't see Insteon Actions (described in your feature list) anywhere. don't know where they are supposed to be
      thanks again
      sjw
        Steve,
        please turn on detailed debugging and poll the iolinc and post the log entries captured during the poll event. maybe the iolinc is not responding as expected
        my iolinc is a little newer regarding firmware
        DeviceType=0700
        FirmwareVer=36
        the new insteon actions are avail from the Action dropdown when creating an Event
        Mark
        HS3 Pro 4.2.19.5
          ok
          solved that one. my problem. i had an event that was turning the HS device off after processing the "momentary" request.
          HS device now follows the status from the sensor
          looking good
          i'll let you know if anything new comes up
          thanks again
          sjw
            Originally posted by stevewinick View Post
            ok
            looking good
            thanks again
            sjw
            Where's the "Easy" button when you need it? Glad you got it working.
            Mark
            HS3 Pro 4.2.19.5
              #21
              Steve,
              if you don't mind i would still like you to delete and register your iolinc with detailed debugging On.
              if you can do this, please post the log snippet of just the registration transaction
              i need to see if the older firmware unit is responding differently to the Protocol cmd.
              Mark
              HS3 Pro 4.2.19.5
                #22
                shall do.
                i assume that there is no remote way i can reregister, is there?
                i'll post when i have it
                  #23
                  shall do.
                  steve, if you have access to your hs interface which it seems like you do you can register the iolinc. you don't need physical access to the iolinc.
                  go to the plugin 'manage devices' page, delete the device and then use the 'add device' to reregister it. you just need the insteon id to do this
                  i can wait until later if you prefer, no rush
                  Mark
                  HS3 Pro 4.2.19.5
                    #24
                    no problem. didn't realize i could do it remotely
                    looks like it registered correctly
                    log is attached
                    sjw
                      #25
                      found one strangeness. my 6 button KPL does not show its links:
                        #26
                        Any errors in the log
                        check your insteon.ini to see if the links exist or if the numlinks entry exists
                        Mark
                        HS3 Pro 4.2.19.5
                          #27
                          [Device 12]
                          DeviceID=12.BE.17
                          DeviceName=6 button Wall Switch
                          DeviceLocation=Avi's Room
                          DeviceType=011B
                          FirmwareVer=36
                          EEValues=DefaultRampRate=28,ResumeDim=136,FPTYPE=0,DefaultOn Level=255,OnLEDMask1=0,OnLEDMask2=0,OnLEDMask3=0,OnLEDMask4= 0,OnLEDMask5=0,OnLEDMask6=0,OnLEDMask7=0,OnLEDMask8=0,OffLED Mask1=0,OffLEDMask2=0,OffLEDMask3=0,OffLEDMask4=0,OffLEDMask 5=0,OffLEDMask6=0,OffLEDMask7=0,OffLEDMask8=0,NonToggleButto ns=0
                          DatabaseDelta=5
                          RecentDatabaseDelta=5
                          PollingInterval=0
                          LastContact=9/28/2010 10:21:19 PM
                          LinksDownloaded=1
                          NumLinks=25
                          Protocol=1
                          TotalInteractions=6375
                          FailedInteractions=49
                          NoChannelSync=0
                          AutoShutoff=0
                          Link 1=E2 03 12 A8 A0 FE 1C 03 1
                          Link 2=E2 01 12 E0 8D FE 1C 01 2
                          Link 3=E2 05 15 B9 21 FF 1F 01 3
                          Link 4=E2 01 13 AC A9 FF 1F 01 4
                          Link 5=E2 03 13 AC A9 FF 1F 03 5
                          Link 6=E2 04 13 AC A9 FF 1F 04 6
                          Link 7=E2 05 13 AC A9 FF 1F 05 7
                          Link 8=E2 06 13 AC A9 FF 1F 06 8
                          Link 9=E2 08 13 AC A9 FF 1F 08 9
                          Link 10=A2 01 12 E0 8D FF 1F 01 10
                          Link 11=A2 01 14 70 8D FF 1F 05 11
                          Link 12=E2 05 14 70 8D FF 1F 01 12
                          Link 13=E2 05 14 72 76 FF 1F 01 13
                          Link 14=A2 01 14 72 76 FF 1F 05 14
                          Link 15=A2 05 13 AC A9 FF 1F 06 15
                          Link 16=A2 FE 13 AC A9 FF 1F 01 16
                          Link 17=A2 01 13 AC A9 FF 1F 01 17
                          Link 18=A2 02 13 AC A9 FF 1F 03 18
                          Link 19=A2 03 13 AC A9 FF 1F 04 19
                          Link 20=A2 04 13 AC A9 FF 1F 05 20
                          Link 21=A2 06 13 AC A9 FF 1F 08 21
                          Link 22=E2 06 0F 88 B1 FF 1F 01 22
                          Link 23=A2 01 0F 88 B1 00 1F 06 23
                          Link 24=E2 04 12 EC 6E FF 1F 01 24
                          Link 25=A2 01 12 EC 6E FF 1F 04 25
                          GroupLinkAddress 1=1
                          GroupLinkAddress 2=2
                          GroupLinkAddress 3=3
                          GroupLinkAddress 4=4
                          GroupLinkAddress 5=5
                          GroupLinkAddress 6=6
                          ChannelName1=6 button Switch ON - Desk HiHat
                          ChannelName2=6 button Switch A - Avis Desk Lamp
                          ChannelName3=6 button Switch B - Avis Unit Flourescents
                          ChannelName4=6 button Switch C - Stereo Main On/Off
                          ChannelName5=6 button Switch D - Stereo Zone 2 On/Off
                          ChannelName6=6 button Switch OFF - Desk HiHat
                          SyncLinkedDevices=1
                            #28
                            your kpl was registered as an i1 but should be an i2 based on the firmware ver.
                            try the following
                            shutdown hs
                            change Protocol=1 to Protocol=2 in the kpl section of the insteon.ini
                            restart hs
                            the use the "reread settings and links" btn
                            Mark
                            HS3 Pro 4.2.19.5
                              #29
                              didn't help, but there was an error log entry:
                              Cmd2: 01
                              9/28/2010 10:58:09 PM - Received a Direct ACK from 0F.88.B1
                              9/28/2010 10:58:09 PM - CheckRawMessageMatch: 01 0F 88 B1 13 AC A9 27 11 01 against key 0* 0F 88 B1 13 AC A9 2* ** **
                              9/28/2010 10:58:09 PM - Wait: Found a matching Insteon raw message: 01 0F 88 B1 13 AC A9 27 11 01
                              9/28/2010 10:58:09 PM - [CheckDeltas] Database recently heard delta value for device 0F.88.B1 is current.
                              9/28/2010 10:58:09 PM - Database delta value of 17 for device 0F.88.B1 is NOT current, database changed since last DatabaseDelta update value of 47.
                              9/28/2010 10:58:09 PM - IOLincClass ProcessStatus called with Level:1
                              9/28/2010 10:58:09 PM - Setting status and value for device ^12. Old status:2 Old Value:100, New Status:2 New Value:100
                              9/28/2010 10:58:12 PM - Edit Links
                              9/28/2010 10:58:12 PM - In Edit - Insteon Device # 12 Addr: 12.BE.17, Name:6 button Wall Switch, Location:Avi's Room
                              9/28/2010 10:58:12 PM - ***:Error in Error In DisplayLinkTable: System.IndexOutOfRangeException: Index was outside the bounds of the array.
                              at WebInterface.DisplayLinkTable(String& data, Boolean ShowChecks): Index was outside the bounds of the array. -- Details System.IndexOutOfRangeException: Index was outside the bounds of the array.
                              --------*End Pre-Error Log*--------------
                              --------*Start C:\Program Files\HomeSeer HS2\Config\Insteon.ini*--------------
                              [Config]
                                #30
                                ok, i need to look into this
                                Mark
                                HS3 Pro 4.2.19.5
