There is a bug in 1.5.5.0 that affects registration of several devices. Please use the version on the following thread instead.
http://board.homeseer.com/showpost.p...9&postcount=42
Here is the next version of the licensed plugin. Please post feedback and issues to this thread.
.Net Framework 3.5 with Service Pack 1 is required
To Install:
1. Backup your current hs database and insteon.ini
2. Shutdown HS
3. Copy the hspi_insteon.dll to the homeseer folder
4. For new users only: copy the insteon.lf to the homeseer\config (this will provide a 30-day trial license), so see the following post starting with Step #2.
http://forums.homeseer.com/showthread.php?t=147802
New Features
- Read and Reprogram Motion Sensor settings without using Linking Mode (ie the internal set btn). Your new settings will be queued and programmed the next time the plugin receives an ON from the motion sensor. To read the current settings (battery level, light level, etc), you can select how frequently they are read from the Device Edit page. Enter 0 to disable this option. Remember, reading the settings too frequently will reduce battery life. Note: Your new settings will not be displayed until the motion sensor is successfully reprogrammed.
- Internal support for the Sage Thermostat Plugin. Requires HS 2.5.0.20 if you use both of these plugins. The HS upgrade is not necessary if you don't use the Sage Plugin.
- Sort the Device Links by number. The setting is on the Main Confg Page.
Revisions
- Saves/reuses the last contact date/time between restarts. This will reduce excessive polling on startup.
- Small internal changes to external device registration code. Existing external scripts should not be affected. Please scream if something is broken.
- Other internal code changes to improve message processing and consistency.
Licenses are available in the Homeseer Store:
http://store.homeseer.com/store/PI-I...n-P948C94.aspx
To Install:
2. Shutdown HS
New Features
Revisions
