Hi MNsandler !
Thx for the latest plugin updates, reliability seems to be improved on our office installation.
I have a new one for you here, very strange :
I want to use our exit keypadlincs to trigger an AWAY event that turns off selected devices and so on. Event actions are pretty basic and are mostly Device turn offs.
If I check the HALL Keypadlinc insteon reliabilityy, it shows 97% which is almost perfect. This keypadlinc is linked to homeseer and a couple other switchlincs and stuff and they all respond quickly and reliably.
The event trigger consists of an Insteon special trigger " transmit an ON comand" that's associated to button C on this particular keypad and there are no conditions.
When I press button "C" ( away ), it should run event AWAY_MODE but nothing happens in the log, seems like homeseer does not receive anything, therefore, not triggering the event.
What's strange is that on first motion in the morning, the HOME_MODE event that triggers fine on motion sends the AWAY button OFF command fine to the keypadlinc and AWAY button "C" turns off fine. That means the servers communicates fine to the keypadlinc but not the other way around.
This is annoying as INSTEON SPECIAL TRIGGERS offer much more options and control than simple device status. Altought in our problem, since homeseer does not receive any communication for the keypadlincs, device status does not work either.
Any insight on how to solve this one-way communication ( server -> keypadlinc ) problem ?
Thx in advance !
Thx in advance !
