I've just purchased 3 Everspring SP103-1 motion sensors.
I've got them set up and working.
About everyday, one of them stops sending (or at least HS stops logging and triggering) motion events.
To resolve, I need to take the motion sensor off the wall and re-install it (switching the tamper switch on and off.)
I cannot figure out why these keep disappearing.
I've set the wake up interval to 240 minutes. Parameter three is set to the default "0".
I've set the dial to the middle of the range (between "T" and "+"). It is about 4.5 minutes.
The batteries report 100%.
They are installed near (within 10 feet) a plug in node that works 100% reliably.
I've successfully optimized all of them in their installed locations.
Where could I look to figure out why these fail to send motion messages to HS?
Thanks, Pete
Thanks, Pete
