Ok, give this a try.
it will not attempt to restart the interface if a device doesn't respond. You can test this by doing a Test Comm on an offline device. The results should be 20 fails, but everything else should contine to work.
This version will attempt to restart the interface if excessive ACKs occur with the PLM or the serial port dies. You can test by disconnecting the serial cable, wait for the "attempting to restart the interface" msgs to start, and then reconnect the cable. the plugin should recover just fine with the 2413s. not so sure with the 2413u.
