So how's this version going? not a lot of noise here so it might be working ok
Insteon PLM Plug-In Version 1.7.0.0 Beta
Mark
HS3 Pro 4.2.19.5
Just in!
Smarthome is shipping devices with their new Insteon protocol called i2CS. When you register one of these devices the protocol will show as i2CS.
V1.7 already has support this new protocol.Mark
HS3 Pro 4.2.19.5
I do have a couple of issues, but it's difficult to tie them to this release.
One issue is in this thread http://board.homeseer.com/showthread.php?t=153215.
The other is with the attached event. The Insteon action works as defined but the HR status shows the previous status of those lights. Polling those lights does refresh the HR status page.
Originally posted by claude View PostI do have a couple of issues, but it's difficult to tie them to this release.
but if the basic problem is that after an Insteon action is executed, and the HS device isn't updated; i can check that out.Mark
HS3 Pro 4.2.19.5
The other is with the attached event. The Insteon action works as defined but the HR status shows the previous status of those lights. Polling those lights does refresh the HR status page.Mark
HS3 Pro 4.2.19.5
Mark its been working great. I'm having an issue with a kepadlinc tied to a new IOlinc I put on my garage door, but I'm not sure I understand the insteon options, I think its me. I need more time before raising it as an issue.
What is in the new insteon protocol now that the cat is out of the bag?Paul
Originally posted by claude View PostAre you saying it's more of an HS issue (which is also what I think)? Or could it be my lack of understanding of HS logic?Mark
HS3 Pro 4.2.19.5
Originally posted by kevini View PostIt's been working great for me too. Very stable.
I second pbibm's request, what's new in I2CS. The internet is still devoid of informationOriginally posted by pbibm View PostMark its been working great. I'm having an issue with a kepadlinc tied to a new IOlinc I put on my garage door, but I'm not sure I understand the insteon options, I think its me. I need more time before raising it as an issue.
Regarding the new i2cs protocol, its intended to improve message reliability.
- cs = checksum, programming msgs must have a checksum
- wired devices must specifically be linked as a responder to the plm before they will accept cmds.
- after a device sends a broadcast msg, it will send a report of how many devices didn't respond with a cleanup msg
- i think the only user feature is the ability to control the number of times cleanup messages are sent after group broadcasts. I'm still researching this for the plugin
- x10 is removed from some devicesMark
HS3 Pro 4.2.19.5
you need to pick the right mode and the "Send on Cmd" option. The defaults on the others should be fine.Mark
HS3 Pro 4.2.19.5
Just to be sure...
Mark, just to be sure I understand...
I reported 2 issues:- One issue is in this thread http://board.homeseer.com/showthread.php?t=153215.
- HR status not updating on an Insteon event
Originally posted by claude View Postmark, just to be sure i understand...
I reported 2 issues:- one issue is in this thread http://board.homeseer.com/showthread.php?t=153215.
- hr status not updating on an insteon event
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostI just installed my 2 yr old iolinc on my garage door but i didn't link it to be controlled by a kpl. Have you reviewed the SH documentation on this setup
you need to pick the right mode and the "Send on Cmd" option. The defaults on the others should be fine.Paul
- x10 is removed from some devicesPaul
