Originally posted by FeMan
View Post
HS2 Insteon Plug-In Version 2.0.0.4 Release
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Posttry to manually link the device to the plm first, then try to register in the plugin
Originally posted by mariusstrom View PostNever done that before, got a pointer to what I should do? (sorry, everything's worked so well in the ~6 months I've been playing with it that I probably don't know some basics!)
both should double beep and then try to register the device in the pluginMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postput the device into linking mode (see the manual) and then put the hub into linking mode (press set btn on back for 3 secs)
Update
By way of an update to the issues I've been having.
I added an X-10 module to the system but was not getting it to respond. There are a number of comments about the INSTEON hub X-10 signal being weaker that standard X-10 transmitters.
I decided to put me CM12U back into service to see if that would help.
It has made the X-10 more responsive but of more interest I haven't had an interface crash since.
Originally posted by IanIreland View PostBy way of an update to the issues I've been having.
could you elaborate on the comment, "I haven't had an interface crash since."Mark
HS3 Pro 4.2.19.5
FeMan
Originally posted by mnsandler View Postthanks for the info. Seems like the hub's buffer isn't getting cleared and is overflowing my code. I should be able to fix this
I'll post something tonightMark
HS3 Pro 4.2.19.5
Originally posted by FeMan View PostMark, do you have any idea when you might have this fixed in V2.0? I have not seen this issue again since reporting it, but I was wondering if there is something I can do via script or something to circumvent the problem?Mark
HS3 Pro 4.2.19.5
However I have a separate problem I am working to resolve with power outs in my home mains supply! I have ELCB on the circuits and the one the PC running Homeseer is on keeps tripping out.
I did have some issues following a 'power out' but a reset of the server, the hub and the X-10 interface seems to have resolved that!
I have installed the new plugin 2.0.0.4 and now have an error from a script.
- Error - Running script, script run or compile error in file: Light Level Script.txt424:Object required: 'hs.plugin(...)' in line 5 More info: Object required: 'hs.plugin(...)'
Here is Line 5
Lightlevel = hs.plugin("Insteon").getdevicesetting("21.XX.XX","Current Light Level") ' Motion sensor
Any ideas?
Originally posted by matt1 View PostI have installed the new plugin 2.0.0.4 and now have an error from a script.
Here is Line 5
Any ideas?
dim insteon as object
Insteon = hs.plugin("Insteon")
Insteon..getdevicesetting("21.XX.XX","Current Light Level")Mark
HS3 Pro 4.2.19.5
Updated to the newest HS2 Version (v2.0.0.4) and linked some more dimmers & 6 buttons today. Had to cycle the power several times from the CB panel for safety reasons. Anyway, I noticed at one point my pool pumps were running and all the Light Dimmers were turned on to 5%. Never seen anything in the general log. I'll report back if it happens again.
One question I have is about the Par38 (2674-222). I can link it to a wall dimmer and control it from HS with no problem. But I am having issues setting ramp rate and dim level using the plugin. Is this supported with your plugin or is it a hardware issue?
Thanks for the great work.
CharlieWayneHSPro: 3.0.0.194
PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
Originally posted by CharlieWayne View PostUpdated to the newest HS2 Version (v2.0.0.4) and linked some more dimmers & 6 buttons today. Had to cycle the power several times from the CB panel for safety reasons. Anyway, I noticed at one point my pool pumps were running and all the Light Dimmers were turned on to 5%. Never seen anything in the general log. I'll report back if it happens again.
CharlieWayneMark
HS3 Pro 4.2.19.5
CharlieWayne
if it is not responding correctly to being controlled via a switchlinc then delete and recreate the links. Otherwise it may be a fw issue.
have you tried including the bulb in a group and see how it doesMark
HS3 Pro 4.2.19.5
