ok since i disabled the write cache - the checkboxes are still marked.
Sync lost
Originally posted by ez1976 View Post
BTW Mark, dont mean to hi-jack the thread but since you removed the fanlinc as a controller, i created some events to turn on the keypad if the fanlink has changed it status and turn it off when i turn the fan off.
this causes major issues with other insteon devices.
i have no idea why but when these events are enabled, if i turn on the fan from the HS's homepage or app it will turn on at 60% all the insteon devices in my house.
i tried it 4 times in a row and it did that
once i removed these events, it stopped (i think it stopped)
do you have any suggests why this could happen?Mark
HS3 Pro 4.2.19.5
Originally posted by gjtherk@comcast.net View PostGentlemen:
In my case, I hadn't added any new devices recently when I started this thread. However, prior to your asking for the testing, I had added an Insteon receptacle, in fact, that was the one I sent since it was the easiest to find in the .ini file.Mark
HS3 Pro 4.2.19.5
Originally posted by ez1976 View PostMark.
as soon as i changed the write-cache the checkbox are still marked.
so is this an HS issue? a windows issue?
anyway this seems to resolve the issue.
hope others with the same problem finds this postMark
HS3 Pro 4.2.19.5
Lost Sync
Make that 3 times. Noticed yesterday that keypads and some switches were not displaying actual status of controlled device. Went through them all this morning and with the exception of 3 lamplincs, the sync box was unchecked.
Nothing else has changed in the system although on Monday we had a number of power failures and re-starts.
I went through all the devices and checked the box again.
I have however, created a backup file of the that will hopefully be of use when it happens again.
Originally posted by gjtherk@comcast.net View PostMake that 3 times. Noticed yesterday that keypads and some switches were not displaying actual status of controlled device. Went through them all this morning and with the exception of 3 lamplincs, the sync box was unchecked.
I'm not sure what to make of this. I just checked several of my devices and they all have the sync still checked. I'm running HS3, but the core plugin code that handles saving ini values is the same between the two plugins.
the backup of the insteon.ini is a good idea. the only downside to restoring it is your device stats will also be rolled back/restored to previous values.
how about this workaround...
I'll added an external script method that will allow you to set the 'sync' option of any device. then you can write a simple script to set all the devices at once.Mark
HS3 Pro 4.2.19.5
Hi Mark:
"how about this workaround...
I'll added an external script method that will allow you to set the 'sync' option of any device. then you can write a simple script to set all the devices at once. "
As I went through the exercise this morning I actually wondered if that would be possible. I'm not much of an I-T guy so my imagination is often out of sync with reality.
I think that is a great idea. Would actually save a lot of time with one less click per device for someone setting up a system.
I haven't upgraded to V3 yet. I'm not too excited about re-building all the events.
Gary T.<!-- / message --><!-- sig -->
Gary,
give this version a try. also attached is a sample script
use the following cmd to run the script
hs.runex("setlinked.vb", "main", Nothing)Last edited by mnsandler; October 8, 2014, 04:01 PM.Mark
HS3 Pro 4.2.19.5
Originally posted by gjtherk@comcast.net View PostThanks Mark. Does the script go into the config folder?Mark
HS3 Pro 4.2.19.5
