Hopefully I didn't screw it up this time. They are in and running.
Sync lost
Originally posted by gjtherk@comcast.net View PostAnd as soon as I unclicked a sync box on a device the log filled up with red ink and the system crashed.
http://board.homeseer.com/showthread.php?t=162864Mark
HS3 Pro 4.2.19.5
ok. good. I'll see if i can get someone else to test the newer version and get back to youMark
HS3 Pro 4.2.19.5
Update
Hi Mark:
Noticed syncing problem again today. I would say about 75% of my devices lost the checkbox. I did add a device today - an Insteon receptacle. Added 3 last week with no impact on syncing so I don't know if there is a relation. Not an end-of-the-world, but is annoying having to go through all of the devices and re-check the sync box.
Gary T.
Gary T.
give this version (2.0.0.13) a try:
shutdown hs
put the DLLs in the attached zip into the homeseer root folder (replacing the existing files)
restart hs
use the script from post #27 above as we discussedAttached FilesMark
HS3 Pro 4.2.19.5
Thanks Mark. I installed the new DLLs in the root directory, verified that the script was in the script directory. Restarted and unchecked a "sync" box on a device. I entered &hs.runex("setlinked.vb", "main", Nothing) in the immediate script command.
The sync box remained unchecked.
I entered the command exactly as above. Do I have that right?
Gary T
Also, I noticed in the two times I ran that script, immediately after in the log I see the following for a device that I don't believe resides in my system.
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0> <TBODY> <TR> <TD class=LOGDateTime0 noWrap align=left>10/26/2014 7:23:05 PM </TD> <TD class=LOGType0 colSpan=3 align=left>Insteon </TD> <TD class=LOGEntry0 colSpan=8 align=left>Device ID 1F.67.58 not found.</TD></TR></TBODY></TABLE>
Originally posted by gjtherk@comcast.net View PostAlso, I noticed in the two times I ran that script, immediately after in the log I see the following for a device that I don't believe resides in my system.
ID 1F.67.58 is one of mine. you need to edit the script to add individual lines for your devices. see below
sub main(parms as object)
hs.plugin("Insteon").SetDeviceSyncLinkedDevices("AA.BB.CC", True)
hs.plugin("Insteon").SetDeviceSyncLinkedDevices("XX.YY.ZZ", True)
rem add a new line for each device
end sub
replace aa.bb.cc, xx.yy.zz, and so on with yoursMark
HS3 Pro 4.2.19.5
Originally posted by gjtherk@comcast.net View PostI have never edited a script. I took yours, saved as a .txt file, edited it and when I saved with the .vb extension, it seems to remain as a text file. I've been searching for some guidance on this, but not having any luck.
Or download notepad++Mark
HS3 Pro 4.2.19.5
