Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer IFTTT Channel Integration
HomeSeer IFTTT Channel Integration General Discussion of HomeSeer's IFTTT Channel
  #61
Old August 17th, 2015, 08:12 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
No.
Originally Posted by pdolan View Post
Can IFTTT be used with HS2? It seems like it can from other posts but when I got to register it won't accept my account. Thanks for any help you can offer.
  #62
Old August 25th, 2015, 08:07 AM
VirtualPanther's Avatar
VirtualPanther VirtualPanther is offline
Angry
Channel is not working:
I tried updating the channel, re-authenticating, etc. to no avail:
  #63
Old August 27th, 2015, 07:18 AM
Moskus's Avatar
Moskus Moskus is offline
AAAARGH!
Got the "Options unavailable" thing again!
Had to reactivate the HomeSeer channel.
  #64
Old September 7th, 2015, 11:15 PM
aperkin2 aperkin2 is offline
Originally Posted by Moskus View Post
AAAARGH!
I'm getting the same. My Homeseer recipes have not worked since around Aug 17. I've reconnected the channel and even removed and re-added the channel. Still getting 'options unavailable'.
Anyone figure this out yet? I'm
  #65
Old September 8th, 2015, 01:54 AM
Moskus's Avatar
As I said, all I did was to make sure HS3 was connected to MyHS and then re-activate the channel. Then it worked.
  #66
Old September 8th, 2015, 09:59 AM
rjh's Avatar
rjh rjh is offline
We are looking into IFTTT now, will post when I have more information. The work done with the Amazon Echo has affected it, possibly.
  #67
Old September 8th, 2015, 10:11 AM
CouchPotatoe's Avatar
CouchPotatoe CouchPotatoe is offline
Any chance you can fix the wrong time stamps at the same time ?
http://board.homeseer.com/showthread.php?t=175232
  #68
Old September 8th, 2015, 12:26 PM
mrhappy mrhappy is offline
I also have issues, I have reconnected the channel in IFTTT (after my recpies failed to work). Have had some patchy performance with adding actions where the list of devices would not populate or giving an error but in the end it appears to have worked again. Is it possible to somehow test or get an alert if the channel has issues?
  #69
Old September 8th, 2015, 12:50 PM
rjh's Avatar
rjh rjh is offline
I checked and we do not send the time to IFTTT. I logged into my IFTTT account and there is a setting there for timezone, see if yours is set properly.
  #70
Old September 9th, 2015, 02:38 PM
rjh's Avatar
rjh rjh is offline
We just finished some work on the server and did a bunch of testing, everything appears to be working ok, please post is you see any IFTTT issues.
  #71
Old September 9th, 2015, 03:04 PM
I'm still getting "Options unavailable, please try again later!", even after doing a disconnect/reconnect.
  #72
Old September 10th, 2015, 02:32 AM
Moskus's Avatar
It works here.
  #73
Old September 29th, 2015, 06:18 PM
chiphead chiphead is offline
Seer Plus
IFTTT not working after update
I have two HS3 systems, because of this I have been using two IFTT accounts. It has worked well since April but the other day I lost the ability to connect with my primary HS# unit.
I am getting "options unavailable try again later" when trying to create a recipe so it appears it isn't connecting with the machine.
I have tried checking and unchecking the "No password required for local logins" with no difference. I am just wondering when IFTTT added unlimited DO buttons did something change.
I use to stay logged into the IF app with one HS3 machine and stay logged on to the DO app with the other machine. This no longer seems to work.
Any ideas?
  #74
Old September 30th, 2015, 10:43 AM
rjh's Avatar
rjh rjh is offline
Try removing and re-adding the channel to the account with an issue. There is no reason multiple accounts will not work, I think I have 4 of them.
Any ideas?
  #75
Old September 30th, 2015, 02:45 PM
I'm still having some IFTTT issues. For quite a few weeks, I was not getting from my HomeSeer connection. Now I can see a list of devices in IFTTT but no Events. Not sure what else to look at. Any ideas from anyone?
  #76
Old October 1st, 2015, 06:02 AM
Thumbs down
Yet again, for umpteenth time, IFTTT recipes stopped working., When checked, it tells me to try reconnecting HomeSeer channel. When I do, it says, "Could not reconnect channel"....
Definitely NOT anything even remotely reliable. Only to be used for fun (or frustration, depending on the stars that day)
  #77
Old October 1st, 2015, 07:31 AM
Moskus's Avatar
It has actually been rock solid for me the last couple of weeks. Even faster it seems after the .206 update.
  #78
Old October 1st, 2015, 07:32 AM
I don't think my problems are with HomeSeer. I just have not seen IFTTT being that most reliable...
  #79
Old October 1st, 2015, 05:31 PM
Do you happen to use Homeseer events? Just curious if I'm the only one seeing devices but not events.
  #80
Old October 2nd, 2015, 06:26 AM
Moskus's Avatar
No, I don't trigger something in HS from IFTTT, just the other way around. But I will have a look.
EDIT: No, my Events show up fine.
IFTTT Android App spud IFTTT (3P) 4 October 12th, 2015 07:15 AM
IFTTT plugin spud HomeSeer General Discussion Area 6 November 8th, 2014 01:31 PM
IFTTT By IFTTT Ultrajones UltraMon HSPI 3 June 6th, 2014 08:35 AM
Ifttt.com plugin? Jakob.Sand Blade Plug-Ins 9 February 15th, 2014 08:26 AM
