Okay I was not quite sure what you meant on 8/15 that you were using the drivers (not HS3) and remotely... I thought once I installed the HS3 Pi OS it had drivers that were providing the middleware between the GPIO and the Ethernet interface so I didn't need the Homeseer software running. I didn't realize I needed HS3 running still as it's the conduit to the Ethernet adapter and provides port communications. Sorry, I was basically thinking serial to Ethernet middleware.
So my next step is to get the HS3 system online and the connect the Z-NET device as the controller then migrate a node for testing. Btw I am documenting this entire process to post here later as reference for others. I will need them anyway since I have another Pi I want to test as a remote controller in the same fashion.
