HS3 Insteon Plug-In Version 3.0.6.49 Beta (Win & Linux)..In Beta section of Updater7
    #61
    No problems on my end.
      #62
      Originally posted by mnsandler View Post
      Possibly. give it a go and let me know
      I'm still having an issue with the Beta where my IOLinc sensor is incorrectly being reported as changing state. It's only happening once every 2-3 days, and I've attached a log of one incident, below.
      For comparison, I NEVER had this occur prior to installing the Beta (and I've been using the Insteon plugin since the end of February).
      The issue with the Beta where an incorrect Unknown value = 0 was being reported on loss of comm. (causing the system to think that the garage door had been opened) occurred 3-4 times per day until it was fixed (thanks, for that).
      Sep-27 11:01:28 PM Event Event Trigger "Notifications Unsecure System Status"
      Sep-27 11:01:28 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:100 Old Value:100, New Status:3 New Value:0
      Sep-27 11:01:28 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
      Sep-27 11:01:28 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
      Sep-27 11:01:28 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
      Sep-27 11:01:28 PM Insteon Received STX 0x50 (Raw Insteon Rec):1F C3 AA 2A 01 80 26 00 00
      Sep-27 11:01:28 PM Insteon ..Got RF PLM Response 02 62 1F C3 AA 0A 19 01 06
      Sep-27 11:01:28 PM Insteon Saved ini file. msecs=14
      Sep-27 11:01:28 PM Insteon Sending command 02 62 1F C3 AA 0A 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Sep-27 11:01:28 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
      Sep-27 11:01:28 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
      Sep-27 11:01:25 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
      Sep-27 11:01:25 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
      Sep-27 11:01:25 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 27 00 00
      Sep-27 11:01:25 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
      Sep-27 11:01:25 PM Insteon Received STX 0x50 (Raw Insteon Rec):1F C3 AA 2A 01 80 27 00 00
      Sep-27 11:01:24 PM Insteon ..Got RF PLM Response 02 62 1F C3 AA 0A 19 00 06
      Sep-27 11:01:24 PM Insteon Sending command 02 62 1F C3 AA 0A 19 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Sep-27 11:01:24 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
        #63
        Have you tried the latest beta. I changed the unknown value to -1
        Mark
        HS3 Pro 4.2.19.5
          #64
          Yes, I'm now using 3.0.6.22. That unknown value issue looks like it's been fixed (thanks). This appears to be different - an ack from the I/O Linc is received, but the state of the sensor is toggled. On the next polling cycle (I poll this device every minute), the sensor is toggled back to the correct state.
          This hadn't happened with 3.0.6.0 since February. I only started to experience these false sensor readings when I switched to the beta.
            #65
            do you have a detailed log snippet that shows the input sensor changing status back and forth after a second polling
            Mark
            HS3 Pro 4.2.19.5
              #66
              I've expanded the earlier snippet I posted (filtered for device 1F.C3.AA), to show the value change on the next polling interval.
              I was hoping to catch a new event, but ran into an issue with polling of the device becoming disabled. I'll put that in a new post.
              Sep-27 11:02:44 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:0 Old Value:0, New Status:2 New Value:100
              Sep-27 11:02:44 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
              Sep-27 11:02:44 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
              Sep-27 11:02:44 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
              Sep-27 11:02:42 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
              Sep-27 11:02:42 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
              Sep-27 11:02:39 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
              Sep-27 11:02:39 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
              Sep-27 11:02:39 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
              Sep-27 11:02:39 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
              Sep-27 11:02:39 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
              Sep-27 11:02:39 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
              Sep-27 11:02:39 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/27/2017 11:01:28 PM. Polling interval of 1 min. reached, polling...
              Sep-27 11:01:24 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
              Sep-27 11:01:24 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/27/2017 11:00:14 PM. Polling interval of 1 min. reached, polling...
                #67
                I encountered another issue, where after a second unsuccessful polling attempt of my garage door I/O Linc, the value for the sensor (1F.C3.AA:1) was changed from 'Unknown' (-1) to 'Open' (0), and polling became disabled for that I/O Linc (polling interval set to 0). Is that intended behavior? I didn't realize that polling had been disabled until I reviewed the log last night.
                Thanks.
                Sep-29 1:59:42 PM Insteon Warning! Polling failed twice for device: Access Garage Door (1F.C3.AA)
                Sep-29 1:59:42 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:-1 Old Value:-1, New Status:3 New Value:0
                Sep-29 1:59:42 PM Insteon Did not get any status response from 1F.C3.AA after 5 tries. No change to database delta value.
                Sep-29 1:59:42 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #5 failed.
                Sep-29 1:59:39 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #4 failed.
                Sep-29 1:59:35 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #3 failed.
                Sep-29 1:59:31 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #2 failed.
                Sep-29 1:59:28 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
                Sep-29 1:59:24 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
                Sep-29 1:59:24 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
                Sep-29 1:59:21 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
                Sep-29 1:59:21 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
                Sep-29 1:59:21 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
                Sep-29 1:59:21 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
                Sep-29 1:59:21 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
                Sep-29 1:59:18 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
                Sep-29 1:59:18 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
                Sep-29 1:59:18 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/29/2017 1:58:12 PM. Polling interval of 1 min. reached, polling...
                Sep-29 1:58:12 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:0 Old Value:0, New Status: Unknown New Value: -1
                Sep-29 1:58:12 PM Insteon Did not get any status response from 1F.C3.AA after 5 tries. No change to database delta value.
                Sep-29 1:58:12 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #5 failed.
                Sep-29 1:58:09 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #4 failed.
                Sep-29 1:58:05 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #3 failed.
                Sep-29 1:58:02 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #2 failed.
                Sep-29 1:57:58 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
                Sep-29 1:57:55 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
                  #68
                  This is not going to be easy.
                  The first poll of the sensor produced the following:
                  The second poll of the sensor produced the following:
                  these two responses would indicate a status change.
                  Mark
                  HS3 Pro 4.2.19.5
                    #69
                    Thanks.
                    I did add a feature that disables polling after two unsuccessful attempts. you can override the default below. Add the key/value to your ini and set to 0 to completely disable. Otherwise increase 2 to 5 for instance.
                    [Config]
                    FailedPollThreshold=2
                    Mark
                    HS3 Pro 4.2.19.5
                      #70
                      [Config]
                      Thanks for the info. I'll make that change. FWIW, I'd prefer an option to never disable polling, even on total loss of comm.. The comm. reliability for my garage door I/O Linc is only around 91% (detached garage, at the back of my yard), and I can see the potential for polling being disabled due to loss of power to the I/O Linc (circuit breaker trip, for example) without notification. Just my $0.02.
                      It appears that there is still an issue with the device value being changed from -1 to 0 on the second unsuccessful polling attempt.
                        #71
                        Originally posted by mrceolla View Post
                        Hi Mark,
                        I've received my replacement Siren and there was no change the behavior I described above. Have you had a chance to look into that at all?
                        no, i'll take a look soon
                        Mark
                        HS3 Pro 4.2.19.5
                          #72
                          I agree. This appears to be the same issue reported by Burrington in another thread.
                          I've filtered my log to show only the ACKs around the false sensor setting (below). It looks like the I/O Linc sensor is being polled 3-5 seconds after the relay contact.
                          The incorrect ACK received at 'Sep-27 11:01:28 PM' also has a different 'Hops Left/Max Hops' value ($6) than the previous ACKs, so it doesn't appear that the plugin is using stale data.
                          Sep-27 11:05:18 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
                          Sep-27 11:05:14 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
                          Sep-27 11:03:58 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
                          Sep-27 11:03:54 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
                          Sep-27 11:00:14 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
                          Sep-27 11:00:10 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
                          Sep-27 10:59:02 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 27 00 01
                          Sep-27 10:58:58 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
                          Sep-27 10:57:44 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
                          Sep-27 10:57:39 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
                            #73
                            I think I finally found the issue. i'll post 3.0.6.23 to the beta section of the updater
                            Mark
                            HS3 Pro 4.2.19.5
                              #74
                              [Config]
                              I added "FailedPollThreshold=0" to the [Config] section of my Insteon.ini, but it gets deleted any time the .ini is updated for any reason. Any ideas?
                                #75
                                Shutdown plugin. Added key. Restart plugin
                                Mark
                                HS3 Pro 4.2.19.5
