Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
  #241
Old June 4th, 2018, 02:46 PM
claude claude is offline
Originally Posted by mnsandler View Post
All,
i just posted 3.0.6.37 in the beta section of the Updater. I added a light sensitivity setting which i think aligns with the insteon app setting. Please test and report back here.
PS. looks like the led brightness setting isn't supported in fw 46, and the LED on/off only works when using USB power.
Hi Mark,
Not sure if this is related to the addition of the sensitivity level, I suspect one of those weird kinks but here goes.
After updating to .37, I was erroneously expecting a new link to show up (I now know it's a setting). So I did a "Reprogram device for HomeSeer': I ended up with duplicate links. So I then deleted all links and did another "Reprogram device for HomeSeer': no links would display, I tried this a few times. I turned on detailed logging and did another "Reprogram device for HomeSeer': finally the links appeared.
The 'battery level' channel and the new 'light level' channel have no associated link but they do appear as HS3 devices.
Thanks for adding the 'sensitivity level'. Now the challenge is to determine which level produces the right result.
  #242
Old June 4th, 2018, 02:54 PM
mnsandler's Avatar
Insteon Overlord
Originally Posted by claude View Post
Hi Mark,
the battery level and light level are pseudo devices. not related to a link.
not sure about the the dup links.
thanks for testing; hope you figure this setting out; since its a % i don't see how this relates to the actual light readings.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
  #243
Old June 4th, 2018, 05:29 PM
With the MS-1, the plugin 'Sensitivity' program setting, from what I gather, was the crossing point (0-255) at which the MS-1 would report Dawn/Dusk if the light level was travelling downward or upward from that value.
Currently with the MS-2, it seems that Dusk is called when the light level is going down and crosses 62 while Dawn is called when light level is going up and crosses 80. I suspect the MS-2 'Light Sensitivity' program setting spreads apart those settings by a percentage. How exactly that percentage is used? Only testing will say.
I assume the dev notes on this have no details?
  #244
Old June 4th, 2018, 07:49 PM
mnsandler's Avatar
Insteon Overlord
claude,
the dev notes are extremely vague on this setting. i checked the insteon app and the setting is between 1 and 100% but i don't know how that translate to an actual byte value. I made an assumption it was similar to the MS 1 which has values of 0 to 255 which i just translated into percentages for the MS II.
i have an email into my SH contact on the subject.
  #245
Old June 6th, 2018, 01:00 PM
mnsandler's Avatar
Insteon Overlord
claude,
claude,
forget the sensitivity setting; its not implemented in this MS II. why did SH put it in the insteon app? who knows.
i'm checking on settings that will affect the dawn/dusk device
  #246
Old June 6th, 2018, 02:23 PM
mnsandler's Avatar
Insteon Overlord
there does appear to be a working Dark Threshold and Light Threshold that are user settable. I'll see if i can add these as Settings in the next beta.
  #247
Old June 6th, 2018, 04:37 PM
tallguydirk tallguydirk is offline
I am getting all kinds of false positives with the occupancy sensor. I have it mounted outside (replacing the MS I that failed) and there has been nothing to trigger it other than maybe light changing. Or maybe the wind blowing and causing the unit to bounce around on that floppy *** mount. Is there any way to adjust the occupancy sensor sensitivity?
  #248
Old June 6th, 2018, 04:42 PM
mnsandler's Avatar
Insteon Overlord
there are no sensitivity settings. i have one on my front porch and i had to mount it sideways pointing down because it was picking up cars driving by when i had it mounted vertically/upright. i don't use the included mount. i just mounted it with velcro/double sided tape to the porch ceiling.
  #249
Old June 8th, 2018, 04:36 PM
mnsandler's Avatar
Insteon Overlord
Just posted 3.0.6.38 to the beta section of the updater. I removed the non-functioning sensitivity setting and add three: Dark threshold, Light Threshold, and a Transition Interval delay
  #250
Old June 9th, 2018, 04:14 PM
Just installed .38.
I have been seeing strange behaviour from the MS II's for the dusk/dawn channel. One of the 2 I have seems to only report at dawn:
Jun-08 19:42:01 CVlog MS2 dusk/dawn changed to 100 - Light level: 34
Jun-08 18:40:45 CVlog MS2 dusk/dawn changed to 0 - Light level: 84
Jun-06 19:07:31 CVlog MS2 dusk/dawn changed to 100 - Light level: 14
Jun-06 18:38:14 CVlog MS2 dusk/dawn changed to 0 - Light level: 87
Jun-05 19:00:27 CVlog MS2 dusk/dawn changed to 100 - Light level: 38
Jun-05 18:48:09 CVlog MS2 dusk/dawn changed to 0 - Light level: 101
Jun-04 19:43:24 CVlog MS2 dusk/dawn changed to 100 - Light level: 11
This one is in the kitchen, so eventually we turn the lights on when it's dark. I would expect the MS to send an entry when it senses darkness, at sunset and when we turn off the lights, and other entries when we turn on the lights. Not so according the the log. The new settings (Night/day threshold, Transition Interval) might help make this more precise. I'll keep monitoring before defining new events.
Mark - is it a correct assumption that Night/day threshold = 0 leaves the dusk/dawn at default? And by the way, what are the default thresholds for dusk/dawn?
  #251
Old June 9th, 2018, 06:14 PM
mnsandler's Avatar
Insteon Overlord
i try to indicate the default value in the drop down list with an *
in this case
night is 64
day is 80
0 is not a default; it just means the current value hasn't been read from the MS.
if the MS is on a battery, hit the set button and try to read the links and settings
if on usb power, just read the links and settings
  #252
Old June 10th, 2018, 03:00 PM
in this case
night is 64
day is 80
Right on! Got it.
No big deal, but just noticed that the Transition Interval appears not to be read in when reading links & settings. Mine stayed at 0:01 while the default is 7:00.
  #253
Old June 10th, 2018, 03:43 PM
mnsandler's Avatar
Insteon Overlord
Right on! Got it.
put the ms into linking mode and set a new value (say 1 min) and then read it back.
  #254
Old June 11th, 2018, 01:23 PM
mnsandler's Avatar
Insteon Overlord
found a bug related to the display value of the Transition Interval.
I'll fix in next beta along with anything additional reported here
  #255
Old June 23rd, 2018, 12:12 PM
mnsandler's Avatar
Insteon Overlord
claude,
the latest beta fixes the value display issue with the MS II
  #256
Old June 23rd, 2018, 05:55 PM
claude,
Great, all fine now. Thanks.
  #257
Old July 14th, 2018, 10:31 AM
LeeIII's Avatar
LeeIII LeeIII is offline
Temperature value display
Hi Mark, thanks for adding the MSII support! I really like these little guys so far.
Of the 3 I have added to HS so far, I noticed that the temp display is inconsistent. One has an "F" and the other two do not.
66.1F Sensors Motion Office Motion Sensor II - Temperature Yesterday 11:18:53 AM
71.9 Sensors Motion Master Bedroom Motion Sensor II - Temperature Yesterday 10:30:42 PM
71.9 Sensors Motion Upper Hallway Motion Sensor II - Temperature Yesterday 11:11:06 PM
All 3 of the MS II have FW 46.
And I'm running your PI v3.0.6.39
--Lee
"We can't solve problems by using the same kind of thinking we used when we created them."
--Albert Einstein
  #258
Old July 14th, 2018, 04:27 PM
mnsandler's Avatar
Insteon Overlord
strange. were all three registered with same version of the plugin?
check the status/graphics tab with the hs device and see if all three look the same or different. please provide screen shots of the differences
  #259
Old Yesterday, 08:23 PM
LeeIII's Avatar
It appears that there is a difference in the scale display character on the Advanced page. These are all new MS II that I just got in a single order. Attached are the differences.
  #260
Old Yesterday, 08:56 PM
mnsandler's Avatar
Insteon Overlord
not sure why multiple new devices added with the same plugin version would turn out different configurations.
try the following for the devices missing the scale F setting
shutdown the plugin
added RecreateDevice=1 to the [device x] section of the insteon.ini
restart the plugin
HTML code is On
Programming Insteon Motion Sensor JimSpy Insteon Plug-in (Mark Sandler) 1 September 19th, 2016 09:20 PM
Insteon Motion Sensor BIGMACK48 RFXCOM Plug-In (3P) 1 April 23rd, 2010 07:11 AM
Insteon motion sensor compatibility? jdls HomeSeer General Discussion Area 2 November 2nd, 2009 12:08 PM
INSTEON Motion Sensor support? vansluis Insteon Plug-in (Mark Sandler) 56 July 20th, 2009 06:07 PM
Insteon Motion Sensor jamesx0 ISY Plug-in Beta (3P) 5 November 12th, 2008 04:10 PM
